Old 05-31-2010, 06:56 AM   #556
The Teacher's Avatar
Trader Rating: 48 (100%+)
Oggie, are you sure about that price difference? Where are you getting your diff parts...
The Teacher is offline   Reply With Quote
Old 05-31-2010, 07:44 AM   #557
RC MARKET's Avatar
Originally Posted by dameetz View Post
you have this already?
YES
Sakura Zero - New Touring Car!-3r-sak-354wo.jpg   Sakura Zero - New Touring Car!-3r-sak-364wo.jpg
RC MARKET is offline   Reply With Quote
Old 05-31-2010, 08:45 AM   #558
dameetz's Avatar
Originally Posted by RC MARKET View Post
YES
Ok I ll get it from you soon, I m still waiting for the new 3Racing PINK heat sink+fan and the gear diff. If all of 'em available I ll get it in one order.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-31-2010, 12:05 PM   #559
RC MARKET's Avatar
Pink heatsink arrived !
gear diff later ! testing only !
Old 05-31-2010, 06:51 PM   #560
Default few Q and A
hi all
first thing i've run the car a few times now outside only
hand trouble with ride height as well all know due to wrong springs
i received the correct springs thnx the 3racing ride height and handling were both better however had issues with droop not enough on the front or rear really
i had the same thing happen with the rear off the car snapping out mid corner made a few changes to the car the best thing was 3 deg rear block also made adjustment to rear sway bar as well seem to settle it down
i have found a good balance now using tamiya shock body with the zero piston shafts and all the pink bits using the black kit spring on the front and tamiya short white spring on the rear
im able to get down to 4mm ride height all round with more an enough droop
upto 10mm if u remove screws all the way
must say the dust covers for the diff are a bit pants ive managed to fit xray ones to it
as for the talk off the 416 front shock tower fitting i have tried two now and neither fit correct with out having to mill the tower Grrr which i don't want to do
what are the difference with the narrow suspension holders thats due out
also this gear diff ya all talking about can someone point me to a pic somewhere i have the roller diff on order ?
tourer is offline   Reply With Quote
Old 05-31-2010, 09:50 PM   #561
dameetz's Avatar
Originally Posted by old-man View Post
I had similar problem like you do, the car snaps half way through the turn. It turned out that the optional 66g motor weight was the cause of it. Took that out and the car was on rails. The 66g weight is now a carbon print paper weight on my desk.
i wonder why the weight causing that? is the motor weight (66g) it too heavy? which way does it snaps? right turn corners or left turn corners? i just tested this car on asphalt track and having oversteer only with right turn corners. Before this I race this car on carpet and it was spot on, left and right steering were equal, no snaps or oversteering.
My car is balance using 20g weight on the batt only, steering throws are set equal on Hudy station, tyres use normally Sorex 40 and Sweep 36exp. Ironically, my 416X(incl 416WE and my friends' 416s) oversteer only to the left corners only which i never managed to solved by set up.
Old 06-01-2010, 06:23 AM   #562
I got the prices off the RC Market site. 3R Aluminium Ball Diff for 416 US$14.90, whereas the equivalent parts for the Sakura Zero add up to $27.89. Of course, more than these components are needed for a complete ball diff (bearings, balls, pulley, etc).
It would be nice if 3Racing did a cheap diff kit for the Sakura Zero like they do for the 416...
Oggie is offline   Reply With Quote
Old 06-01-2010, 01:34 PM   #563
Default Rc Market
hi all can someone help
im unable to make a purchase on rcmarket
i cant select the box to make the cursor appear and start to flash so i can enter my details
can someone see they are having the same thing happen to them or is it just me
Old 06-01-2010, 01:42 PM   #564
Troy1x's Avatar
Use IE not Firefox, Firefox does not work on RCmarket except for browsing. I did that last night found everything I needed then realized I was in Firefox so I had to do it again in IE.
-Troy
3Racing Sakura Zero - Powered by Tekin RS
Troy1x is offline   Reply With Quote
Old 06-01-2010, 03:29 PM   #565
Default firefox
-Troy
thanks for the info mate will again try now hope it works
Old 06-01-2010, 06:07 PM   #566
nice one mate got me bits ordered worked fine
Old 06-01-2010, 11:28 PM   #567
alphaqgti's Avatar
Default Let's play a little game...
... can you spot the non-Sakura parts?
A little closer so you all can see
Still can't tell? How about now?
"Why?" you ask? Well I had a race this past weekend and my parts didn't make it on time, so I had to improvise a bit. Everything worked out well on the asphalt. I just might end up keeping it this way. I think I'll call it "Sakumiya!"
| Sakura Advance | Sakura XI | Sakura D4 | Fujin 211Go | Lightning FXM | F103.5 | M05 v2 Pro | TA05R | TA05 IFS-R | TA04R | TB Evo1 | TRF501x | TRF201 | DB01-R |
alphaqgti is offline   Reply With Quote
Old 06-01-2010, 11:49 PM   #568
old-man's Avatar
1) Ball Ends
2) Front Swing Shafts
3) Rear Shock towers (with front diff caps!?!?!? Interesting )
4) Front suspension arms
5) "C" Hubs
6) front knuckles
old-man is offline   Reply With Quote
Old 06-02-2010, 07:19 AM   #569
RC MARKET's Avatar
some Tamiya parts !
Old 06-02-2010, 02:52 PM   #570
alphaqgti's Avatar
1) Ball Ends
5) "C" Hubs
6) front knuckles
You found a good number of them! I am using Sakura knuckles tho (those held up surprisingly well).
During the last race I hit a board that was sticking out pretty hard. The hit managed to snap the aluminum swingshaft at the joint, split the plastic spool cup, broke a front arm, and snapped a ball connector on the bellcrank entring a sweeper at full throttle.
My other car is a 416 so I had a bunch of spares on hand to do some frankensteining:
1) Low Friction ball cups - the stock cups had a little too much slop for my liking
2) 46mm Steel Swing Shafts
3) Steel Spool Cups
4) Reversible Front Arms
5) 416 C-Hubs
6) Fluorine coated flanged sleeves & balls - Stock sleeves are too thin, too much slop in the 416 C-Hubs
7) 416 Rear Shock Tower mounted on a set of Sakura front bulkhead uppers - the tower has the center notch in case 3Racing ever releases the chassis balancing station
8) TRF Fluorine Shocks in the rear with Sakura caps & ends
9) TRF Short Damper internals and shafts in front with Sakura shock bodies, caps & ends - the short TRF shafts are a tad longer than the stock ones, gave me a bit more droop that was needed in front
10) Hard 5mm ball ends in the steeing bellcrank
I also have a front 416 tower and the other 2 TRF shocks that I will porbably try out this weekend. I'll see if I like it better than the short front/long rear damper setup the car has now.
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
