Old 05-30-2010, 08:40 AM   #541
dameetz's Avatar
Originally Posted by Andy p View Post
lso am i right in thinking the wishbones are the same as another brand ? (tamiya/xray)
Tamiya 46mm one will fit fine.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-30-2010, 09:44 AM   #542
Andy p's Avatar
what area ?
@ rcmarket ,it will be on cold ish tarmac do you have the spring set in yet?
Thankyou dameetz
Andy p is offline   Reply With Quote
Old 05-30-2010, 10:17 AM   #543
I had a go with my zero for the first time last night , it was good but think it can be better it seemed to have alot of body roll im using tamiya white xhard front springs and tamiya blue hard on the rear and a front anti rol bar , grip was good but i struggled to put the power down out of the corners , it is only a small carpet track so it had alot of tight twisty corners . I hope to try it on tarmac next weekend so any setup info will be good , i havent run tc for a few years so i am abit out of touch with set ups
Tourer, if you read this what tyres are you using outdoor ?
few pics to
hi ya mate im using corally STCC Control Tyre Mounted Tyre thats all i use outside :0)
tourer is offline   Reply With Quote
Old 05-30-2010, 12:03 PM   #544
RC MARKET's Avatar
what area ?
Thankyou dameetz
Tamiya which spring ? white spring set ?
RC MARKET is offline   Reply With Quote
Old 05-30-2010, 01:40 PM   #545
Andy p's Avatar
I mean the 3 racing spring set for the sakura !
Old 05-30-2010, 01:48 PM   #546
RC MARKET's Avatar
they ready release ,
so please wait moment !
Old 05-30-2010, 02:06 PM   #547
RC MARKET's Avatar
New plus 4mm F & R shock tower released !
Old 05-30-2010, 08:11 PM   #548
dameetz's Avatar
you have this already?
Old 05-30-2010, 09:49 PM   #549
old-man's Avatar
Words has been going around on the gear diff for the Sakura. Anyone can confirm this?
old-man is offline   Reply With Quote
Old 05-30-2010, 09:50 PM   #550
cannon's Avatar
Trader Rating: 35 (100%+)
It is already listed on their website. Coming soon. Two sizes ... 37 and 38t . Obviously can also be used on a Tamiya 416 (37t pulley)
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 05-30-2010, 10:45 PM   #551
dameetz's Avatar
its confirmed, lots of pics at the facebook site.
Old 05-31-2010, 01:10 AM   #552
Default Gear Diff
Please excuse my ignorance, but when you refer to this gear diff, are you talking about the one-way that is shown on the 3Racing site, or is this a different item (I don't have access to Facebook at work to check it out further)?
I ran the Sakura Zero for the first time yesterday on carpet with good grip and a fairly tight/technical track and struggled in the corners (going from understeer to snap oversteer) on the corners. I admit that I haven't raced RC for many years, so most of my problems are (lack of) user ability, but nevertheless, I'd like to try a front diff instead of a spool.
Browsing the sites, looking to purchase the parts required to convert the spool, I noticed that 3Racing also do a ball diff kit for the Tamiya 416 (3R-416-10 Aluminium Ball Differential for 416), which looks very similar to the Sakura Zero parts (at least in the low quality photos). Does anyone know if the Tamiya diff kit would fit the Sakura Zero? There is fair difference in price between the Tamiya kit and buying the equivalent parts needed for the Sakura Zero (yes, I'm cheap).
Oggie is offline   Reply With Quote
Old 05-31-2010, 01:23 AM   #553
cannon's Avatar
3 racing are making a one way for the front and a gear diff for the rear
Old 05-31-2010, 01:28 AM   #554
old-man's Avatar
The gear diff mentioned are not the one-way on the 3R site. The one-ways are for the front and the gear diff are for the rear.
I had similar problem like you do, the car snaps half way through the turn. It turned out that the optional 66g motor weight was the cause of it. Took that out and the car was on rails. The 66g weight is now a carbon print paper weight on my desk.
The 416 diff's is about 1mm wider then the Sakura. Besides why would you want to go that way when the 3R Sakura diff is readily available.
Old 05-31-2010, 02:05 AM   #555
Cheers, that answers that question!
OK, then I will have to buy the Sakura Zero parts. As mentioned above, the reason for considering the 416 diff is that I'm cheap - there is about $10 difference between 3Racing's 416 components compared to the Sakura Zero equivalents.
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
