Old 05-18-2010, 04:13 AM   #511
cannon's Avatar
Trader Rating: 35 (100%+)
3 Racing has confirmed the production of two optional shck towers to use longer spring sets
They are now listed on the 3 Racing website in the parts section
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 05-18-2010, 06:16 AM   #512
dameetz's Avatar
Cannon, do I have to use a longer shock body and shaft if i want to use the taller shock tower?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-18-2010, 06:30 AM   #513
Troy1x's Avatar
You might not need to...
But it looks like the beginning of June we could see them, then I could use HPI and Tamiya TRF Springs YEAH!!
Anyone have building instructions on the RDS Diff? Can I use just standard diff grease like Niftech? Anything special that I need to do?
-Troy
3Racing Sakura Zero - Powered by Tekin RS
Troy1x is offline   Reply With Quote
Old 05-18-2010, 06:46 AM   #514
cannon's Avatar
No I believe the plan is to use the standard shocks but should allow the use of longer shocks if you want.
Old 05-18-2010, 07:03 AM   #515
dameetz's Avatar
Great, thanks mate.
Old 05-18-2010, 01:44 PM   #516
alphaqgti's Avatar
Turns out the springs I got in my kit are the correct springs (black in color and stamped 5.5T), but the front end still sits a bit high even with the spring perch at the topmost position. Is the -1mm spring retainer worth getting? Does it remedy the problem?
| Sakura Advance | Sakura XI | Sakura D4 | Fujin 211Go | Lightning FXM | F103.5 | M05 v2 Pro | TA05R | TA05 IFS-R | TA04R | TB Evo1 | TRF501x | TRF201 | DB01-R |
alphaqgti is offline   Reply With Quote
Old 05-18-2010, 05:12 PM   #517
dameetz's Avatar
My replacement came with black springs and the pink aluminum 1mm off set retainer, I haven't fitted it yet though.
Old 05-18-2010, 08:00 PM   #518
What ride height are you seeing fully prepped to run?
The 1mm down perches would drop RD by a good 1.5 to 2mm
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-18-2010, 08:05 PM   #519
-Troy
Re RDS, all that is different is the diff pulley and the rollers, just build it as per normal.
So sand diff rings, apply normal grease, and run in per normal.
The diff action will be tighter than you are used to with a ball diff, just make sure you have the diff tight enough so there is a normal amount of slippage.
Old 05-18-2010, 09:46 PM   #520
alphaqgti's Avatar
I've got 6.5mm up front with the perches all the way up on the kit springs and I'm able to get down to 3mm in the back. I would like to get in the 4-5mm range indoors. Even 6.5mm is a bit much for outside. If you say the new perches can knock off 1.5-2mm that will bring the height down to 4.5-5mm which should do the trick.
Currently I've been testing with the springs from my Fujin 211Go and they seem to be working fine, but then I'd have to order new springs for the Fujin. I'm just trying to figure out which way I want to go - new -1mm spring retainers or new Fujin springs.
Old 05-19-2010, 12:51 AM   #521
Robert_K's Avatar
I've solved my ride height and droop problems:
I've used a Tamiya 416 Front Shock tower (84086).
Used Tamiya Shock bodies, and tamiya suspension shaft (these nice gold looking ones ). I've also used the 1mm down retainers of 3Racing. All the other shock part's I've used the 3Racing parts, the'll wit without problems. Now I can use all the springs I like, so for me that would be the Hot Bodies ones :-)
Now my car is how it should be. Normal droop everywhere , and I can (if I wished to) lower my ride hight to absolut zero, or bring it up to somewhere around 12... In other words, it's solved. I'm really happy with the car right now, and willing to try it on the track this evening, prepairing it for the ETS at Mach Heemstede. Hope it will preform as good as it looks
thanks for the one noticing a 416 shock tower fit... it does!
Best Regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 05-19-2010, 03:30 AM   #522
A Ilievski's Avatar
Trader Rating: 39 (100%+)
For those wondering, the new springs are 20mm high. With the -1mm shock retainers the right height is now fine .
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 05-21-2010, 12:51 AM   #523
RC MARKET's Avatar
Suspension arm restock now !
RC MARKET is offline   Reply With Quote
Old 05-22-2010, 01:48 AM   #524
Default Steering Arm Fine Tuner Option
Can someone please explain what the Sakura Steering Fine Tuner is supposed to do; how it is used?
Oggie is offline   Reply With Quote
Old 05-22-2010, 01:50 AM   #525
A Ilievski's Avatar
You screw that from the bottom side of the chassis into the steering column. It locks it into place so its easier to set your toe adjustments without worrying if the wheels will move.
Alex Ilievski
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
