Old 04-28-2010, 11:24 AM   #376
RC MARKET's Avatar
Roller Diff. pulley & Pin
RC MARKET is offline   Reply With Quote
Old 04-28-2010, 03:39 PM   #377
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Robert_K View Post
Is there a different way to solve the ride height problems? Different shocks? Shock shafts? Collars?
Is there going to be an update from 3Racing?
Best Regards
Robert
Apparently there was an error made when the kits were packed.
The wrong length springs were thrown in !! Minor technical hitch there , though I thought I had made a major cock-up when assembling mine !!
Turns out it wasn't user error......
The shop I purchased mine from, was on the phone to 3 direct on Monday.
They are sending us the proper springs and the -1mm lower retainers, so a good result in the end. Let's call it a teething problem and get RACING !!
fleetmaster is offline   Reply With Quote
Old 04-28-2010, 05:10 PM   #378
Best Regards
Robert
As Fleetie posted, the correct springs will be sent out free of charge.
While i have advised 3R that it is advisable to have the car capable of using regular length TC springs like HPI's, it is in effect no different than a team Magic E4, earlier Yokomo'sor Team Losi JRXS-R needing tiny springs, or a Losi XXXS that needs massive springs, just 4 cars i can think of the top of my head.
There is a sprngs set for the Sakura, with about 8 rates, each only a qtr of a wind apart for fine tuning, so all will be good.
I have requested a taller shock tower to allow regular TC springs, so we will see what happens.
In the mean time i have been working on a few solutions, the easiest implemented will be to use a Tammy shock cap (Possibly even just the plastic ball part) on the kit shock.
Again a small teething issue, not to make the car look bad, much better than most other brands first launches, anyone remember losi arm breakages, Pro4 diff crunching, cyclone diff screws etc
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-28-2010, 08:07 PM   #379
The Teacher's Avatar
Trader Rating: 48 (100%+)
Besercoe, why not use the Losi springs they are short. I would think you would want the lower shock tower right?
The Teacher is offline   Reply With Quote
Old 04-28-2010, 08:29 PM   #380
no need for Losi ones if you buy the 3R springs.
Also, its been said shorter springs dont have the same consistent feel as regular length springs.
Finally, nearly every brand around the world defaults to HPI springs for their team guys (Xray even have a code on their setups 2.6 = HIP Blue 2.8 = HIP Silver, and you are kicked off the team if you ever admit this on the xray forums)
Old 04-28-2010, 08:51 PM   #381
I guarantee the 3Racing springs will be well priced and that the average joe won't have an issue using them either
Old 04-29-2010, 08:30 AM   #382
Troy1x's Avatar
Almost done. Running it tonight
-Troy
Troy1x is offline   Reply With Quote
Old 04-29-2010, 09:18 AM   #383
Looks really nice!
Kiznasty is offline   Reply With Quote
Old 04-29-2010, 09:58 AM   #384
whoopass's Avatar
you guys could also try the rayspeed spring retainer. that would solve the 10mm ride height issue!
whoopass is offline   Reply With Quote
Old 04-29-2010, 10:10 AM   #385
RC MARKET's Avatar
-Troy
Titanium screw !
update roller diff. ?
& don't change belt left to right side ?
Sakura Zero - New Touring Car!-3r-sak01v1.jpg   Sakura Zero - New Touring Car!-3r-sak-02r.jpg   Sakura Zero - New Touring Car!-3r-sak-02rp.jpg
Old 04-29-2010, 10:26 AM   #386
Robert_K's Avatar
Are both the Swaybars and swaybar mountings included in the kit?
As far as I know not???
Best regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 04-29-2010, 11:43 AM   #387
Troy1x's Avatar
They come with the kit including 2 bars, one for the front and one for the rear
Old 04-29-2010, 01:51 PM   #388
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
nobody's really commented on the r.d.s. system. i'm guessing it feels/drives like a tight diff? with the shearing going on, due to the non-tapered pins, has heat been an issue? you might not have to rebuild it much, but if it melts down pulleys ....
i'd be curious, because we're in desperate need of better diffs for these cars (tc in general). though, i think the gear diffs will be the way of the future ...
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 04-29-2010, 02:29 PM   #389
RC MARKET's Avatar
Yes HK near all car was changed gear diff !
Hk used gear diff over 2 years near 3 years !
Old 04-29-2010, 05:33 PM   #390
old-man's Avatar
RC Market,
Whats the difference by switching the belt left to right?
OM
old-man is offline   Reply With Quote
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
