Old 04-24-2010, 07:50 PM   #361
cannon's Avatar
Trader Rating: 35 (100%+)
Originally Posted by The Teacher View Post
I thought the diffs for this car were suppose to be like a totally new design using what looked like a roller bearing style diff balls...? Looks like they went a different direction on a lot of things from the original pictures....
The roller diff is still around. THe roller was always an optional item not standard in the kit
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 04-24-2010, 08:20 PM   #362
Well early on when the pics were posted they didn't say it was an option or standard so some of us assumed it would be standard.
Old 04-24-2010, 08:42 PM   #363
cannon's Avatar
Gadgt
From my recollection early on the roller diff was listed in the list of features as an optional part.
Whatever , the car is a very good quality fit. Everything has gone tiogether very well with very few issues.
It is true that the car has a lot of features the same as the Tamiya.
There are a lot of small things too that are good . Like the steering lock pin that allows you to lock the steering in the centre when doing turnbuckle adjustments etc
Old 04-24-2010, 09:58 PM   #364
Originally Posted by academygaz View Post
SAKURA ZERO Features
01. 2.25mm graphite main chassis
02. 2.0mm graphite long-cutting upper deck
03. Aluminum motor mount, F&R bulkhead with pink anodize.
04. 2 belt drive system
05. 7075 rear rolling differential system (RDS)
06. F&R 38T pulley and 20T center pulley
07. Full ball bearings
08. F&R universal shaft
09. F&R quick change stabilizer
10. 64 titanium turnbuckles
11. Steering locker pin (SLP)
12. Screw-less spur gear adaptor
13. Quick change spur gear mounts
14. Quick change rear differential cover
15. Low CG weight balancer
16. Li-po battery graphite chassis
17. Fixed aluminum suspension mount
18. Smart suspension outer pin
19. Rolling center adjustable shim (0.25/0.5mm)
20. Downstop protection shim
Hi-Res images:
http://3racing.hk/sakura-zero/englis...1_1280x768.jpg
http://3racing.hk/sakura-zero/englis...2_1280x768.jpg
#5 listed as a feature in the kit.
Old 04-24-2010, 11:18 PM   #365
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Originally Posted by cannon View Post
Gadgt
+1. Not everything on the list below is standard.....
The front arms and steering blocks are like Xray items.
I did mention the steering locker in my 3a.m post, which was rather detailed, that was until my browser had an epic fail when I tried to submit !! Hence the brief post !
I left the pin there while I set the servo up, adusted camber and toe out aswell.
fleetmaster is offline   Reply With Quote
Old 04-24-2010, 11:45 PM   #366
cannon's Avatar
They are features of the car. Doesn't necesssarily mean they are standard on the kit
The roll centre shims are not part of the kit either .. but available for the kit
Same for the weight balancers
But whatever .. I am hardly going to complain as the car is great value
Old 04-25-2010, 09:45 AM   #367
Troy1x's Avatar
The RDS was always an option, on 3racings website it states OPTIONAL.
Anyway can't wait for mine to come in Tuesday or Wednesday, taking off a half day to build it. I will be at the track, Thursday-Saturday.
Troy1x is offline   Reply With Quote
Old 04-25-2010, 12:48 PM   #368
All I am saying is the way it was worded was confusing...it is probably a translation thing. Option parts should be listed separately as option parts, not with the rest of the standard parts as that makes it look like they are standard. Unless it is part of the car it isn't actually a "feature" until after you buy it.
Old 04-27-2010, 06:09 AM   #369
Troy1x's Avatar
Ok guys my mini review.
I built the car last night, so far all was good expect a few things.
1. There were four inner hinge pins in the kit one of which was 10mm shorter then the other 3 =(. I still made it work but it looks like I have to order a new set.
2. Next has to be the easy to access spur gear adapter. First I hate those little shims they are a pain. Next you need to run a spur gear with some pretty big holes, these are not for the mounting of the spur gear but to access the motor screws, so you can change pinons. Its also a pain in the butt to remove every time, did it three times and hated it every time.
3. Shock springs - These things are so hard their usable period.
Other then that everything went well, car came together, just have to build the shocks, mount my electronics and figure out weight placement and throw a setup on.
I need to figure out a good spring kit... was thinking of going TA if anyone has any input let me know.
_Troy
Old 04-27-2010, 06:41 AM   #370
They are identical to the 3racing mini shocks, except the collars are three times as thick.
I used the mini springs to obtain the correct ride height. There are also -1mm lower retainers as an optional part. The mini springs did the trick for me though.
Old 04-27-2010, 06:44 AM   #371
Troy1x's Avatar
Get it on the track yet?
-Troy
Old 04-27-2010, 09:25 PM   #372
No, sadly not yet.
Due to some unforseen circumstances, it may not be for a week or two, which is really peeving me to say the least.
But I need some new rubber to do the car justice and my time is a little short at present.
I'll certainly post here when I do run the car.
Old 04-27-2010, 10:03 PM   #373
_Troy
Hi Troy
See the 3r reseller or email 3r direct im sure they will repalce the pins.
Spur gear setup, yeah it is a little fiddly, the 3r guys at TITC showed me the easiest way, they flicked the belt off the front pulley, giving you lots of slack to be able to pull out the layshaft etc. Re spur gear i have tried a few and the kit 3racing spur is by far the easiest, as well as very good quality (easily rates with RW and Xenon)
Springs - Word is ther was a packaging error and the incorrect springs were packs in the kit, i believe replacements will be made available, again see where you purchased it from.
Look forward to seeing how you go on the track.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 04-28-2010, 06:16 AM   #374
Troy1x's Avatar
Ok I found out that having you hinge pin 10mm short does not work and it came out last night while setting droop. So I placed an order for more hinge pins and tons of spares mostly, c-hubs, steering blocks, front and rear arms, a 3 degree toe block and rear hubs.
The next order will be the weights when they get in stock.
I had bought two spur gears neither of them worked so I actually drilled some holes in the spur big enough to adjust the motor and now the spurs work. The problem isn't getting the spur out but putting it back in.
Some other things I found out.
Can't use a 112spur, it clears the diff but not the chassis. I saw in the default setup sheet that a 106 will work, so im guessing thats the highest I can go?
The steering system in this car rocks, love the locker pin and love how easy it is to find zero.
All electronics fit with no problems, Futaba 9551, SR3000, Tekin RS, Duo 17.5 with heat sink and fan.
I will post some picks tonight.
Now I will just have to wait till tomorrow for my pins to come in. First test run will be tomorrow, BTW I am using Tamiya Short Springs which seem to be working perfect right now.
-Troy
Old 04-28-2010, 07:51 AM   #375
Robert_K's Avatar
Is there a different way to solve the ride height problems? Different shocks? Shock shafts? Collars?
Is there going to be an update from 3Racing?
Best Regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
