Old 04-24-2010, 02:06 AM   #346
cannon's Avatar
Trader Rating: 35 (100%+)
Fleety,
just starting on mine
Interestingly a Tamiya 416 diff is a perfect fit in the rear of the car
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 04-24-2010, 03:12 AM   #347
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Originally Posted by cannon View Post
Fleety,
I believe the same brand driveshafts will fit too
LMK how you go with the shocks. They are identical to their mini shocks, bar the collars,which incidentally, prevented me from getting the front below 10mm ride height
I overcame this with the 3Racing mini springs though , the plastic mini collars will help even more, and may allow use of the std springs.
Yet to check this though, much to do on the domestic front first
fleetmaster is offline   Reply With Quote
Old 04-24-2010, 03:47 AM   #348
Looks like I found it, rcmushroom has it for $360 shipped by express mail.
ioxqq is offline   Reply With Quote
Old 04-24-2010, 04:55 AM   #349
cannon's Avatar
Building the car and the design looks very versatile. The car comes with 38t pulleys but they are the same as Tamiya pulleys so if you want to change the internal ratio of the car you can use the 37t tamiya pulleys in comjunction with the Sakuras four different centre pulleys. Makes it easier to combine spur and pinion to achieve rollouts for the spec classes
Old 04-24-2010, 05:43 AM   #350
hacker's Avatar
Trader Rating: 141 (100%+)
are the weight balancers available yet?
hacker is offline   Reply With Quote
Old 04-24-2010, 06:08 AM   #351
cannon's Avatar
Apparently most spares are now in stock.
I have placed an order for most spare parts. Hopefully they will ship next week
Old 04-24-2010, 06:43 AM   #352
I know I'll be wanting all the optional weights plus some spares .....
The quality really has exceeded my expectations by far.
Old 04-24-2010, 07:18 AM   #353
cannon's Avatar
To date I have only had one small issue. The grub screw that locks the hinge pin on the front right C hub didn't actually go close the groove in the hinge pin so it didn't lock the hinge pin in place
Other than that the whole kit has been very good
Old 04-24-2010, 08:04 AM   #354
Must be your eyesight , no problems with mine.....
Mine is a roller,electronics onboard.
To do : swaybars, servo horn/draglink,balance / bring up to min weight.
Then I can set the alignment angles and DRIVE !!
Mind you, I had this all done by 4:30pm yesterday ! Today I've only looked at the shock preload issue.....
Old 04-24-2010, 11:08 AM   #355
Mine is built, except the swaybars
All I want is new rubber, body shell and some of those pretty weights
Old 04-24-2010, 03:26 PM   #356
RC MARKET's Avatar
Yes many spare parts released !
RC MARKET is offline   Reply With Quote
Old 04-24-2010, 03:41 PM   #357
Luppi Stefano's Avatar
HI!
For Italy is free Shipping or not?
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 04-24-2010, 06:41 PM   #358
old-man's Avatar
Fleety,
They fit perfectly because its a copy of Tamiya. I bet the diff/spool bearing holders are the same too.
Hmmm interesting, very interesting indeed.
old-man is offline   Reply With Quote
Old 04-24-2010, 07:17 PM   #359
cannon's Avatar
The 416 diff does fit but there are a few issues if you wanted to use one:
You would need shorter rear bones. The 46mm would bottom out because the Tamiya diff nut is thicker and sits out further into the drive cup. The Sakura has 46mm bones all round. I think the rear could be reduced but will have to check
Old 04-24-2010, 07:35 PM   #360
The Teacher's Avatar
Trader Rating: 49 (100%+)
I thought the diffs for this car were suppose to be like a totally new design using what looked like a roller bearing style diff balls...? Looks like they went a different direction on a lot of things from the original pictures....
The Teacher is offline   Reply With Quote
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
