Old 03-27-2010, 10:08 AM   #286
Originally Posted by cannon View Post
You obviously dont know much about the current range of ESC's. Gearing is vastly different depending on the ESC and whether you are using the turbo function. Use a "starting point" rollout from a non turbo ESC on a turbo ESC and you will blow either the ESC or motor. Fact of life
Actually, as I used to work as an electronics technician, I know enough about the current ESC's to design and build one from scratch (though probably not as cheaply as I can buy off the shelf, so I will simply buy one).
As I am building a new car with all new parts, it will be a current ESC, most likely a Speed Passion GT to match the Speed Passion motor, powering a Sakura Zero.
What is so hard about giving advice along with qualifications? e.g. If you are using a current ESC, try an FDR around ... or if you are using an older ESC ...
If I accepted your advice, I'd never even make a start!
Oggie is offline   Reply With Quote
Old 03-27-2010, 10:13 AM   #287
RC MARKET's Avatar
ready release la !
Pre-order now !
http://rcmarket.com.hk/product_info....oducts_id=8159
Sakura Zero - New Touring Car!-12.jpg   Sakura Zero - New Touring Car!-.jpg   Sakura Zero - New Touring Car!-7075-.jpg   Sakura Zero - New Touring Car!-7075-.jpg   Sakura Zero - New Touring Car!-dsc_8046.jpg
RC MARKET is offline   Reply With Quote
Old 03-27-2010, 10:19 AM   #288
RC MARKET's Avatar
http://rcmarket.com.hk/product_info....oducts_id=8158
Sakura Zero - New Touring Car!-dsc_8427.jpg   Sakura Zero - New Touring Car!-dsc_8430.jpg   Sakura Zero - New Touring Car!-dsc_8432.jpg   Sakura Zero - New Touring Car!-dsc_8434.jpg   Sakura Zero - New Touring Car!-.jpg
Old 03-27-2010, 10:21 AM   #289
RC MARKET's Avatar
Sakura Zero - New Touring Car!-l-.jpg   Sakura Zero - New Touring Car!-.jpg   Sakura Zero - New Touring Car!-.jpg   Sakura Zero - New Touring Car!-12.jpg   Sakura Zero - New Touring Car!-.jpg
Old 03-27-2010, 10:32 AM   #290
RC MARKET's Avatar
Sakura Zero - New Touring Car!-.jpg   Sakura Zero - New Touring Car!-.jpg   Sakura Zero - New Touring Car!-29699.jpg   Sakura Zero - New Touring Car!-03.jpg
Old 03-27-2010, 10:37 AM   #291
cherry2blost's Avatar
Now is that the GT2.0 with or without Supercharger?m
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-27-2010, 04:46 PM   #292
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Here's how it works : you need to be as specific as you can with your questions, in order to get a decent result.
You don't visit a doctor ,saying your leg is sore and nothing else. You can't get shirty when you get an incorrect diagnosis.
Now, there is a massive difference between the 21.5 motor characteristics alone.
Never mind the esc variables ....
What size track / layout / surface / grip ?
Your roll-out can be as low as 40mm or as high as 60 + !!
The SP I had, was up around 61mm with an SPX . Indoors,high grip ,maximum timing on both units.
This was still slower than the same setup, with a Novak motor , geared at 45mm.
1:1 knowledge doesn't always translate into rc that well.
fleetmaster is offline   Reply With Quote
Old 03-27-2010, 05:04 PM   #293
cannon's Avatar
Trader Rating: 35 (100%+)
As has been said until you have an ESC and a designated version of the firmware giving you any advise on rollout could destroy your equipment.
As Fleety said, look at the vast difference in rollout figures for 21.5. If you use the wrong one your ESC and motor are fried
Look at the responses from others on here. They are basically saying the samne thing. Get your ESC and version of firmware then ask the question
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 03-28-2010, 05:59 AM   #294
I'll be old and grey before I get a sensible answer from you guys... oh..., too late! It seems I will have to resort to the old tried and true methods of trial and error. Thanks for nothing.
Old 03-28-2010, 06:11 AM   #295
While you're teaching grandma to suck eggs, it also works this way - if you don't know the answer, it's probably better not to answer at all.
Old 03-28-2010, 06:12 AM   #296
If you are running a STANDARD (Factory) Speed Passion GT 2.0 and a 10.5 and are on a medium sized track, then a good place to start will be around 6.0 on the FDR, Supercharged about 8.0 FDR and 110 software about 7.2 FDR you will need a temperature gun so as not to allow your motor to get above about 160 Fahrenheit.
13.5 about 5.0, 17.5 about 4.5, 21.5 about 4.0
Sorry you feel we haven't helped you out but if we give you an idea and you blow a speedo or motor you will be upset at us.
Old 03-28-2010, 06:46 AM   #297
Finally, someone who is game to at least give some advice! I appreciate it, thank you.
If I blow an ESC or a motor, at least it isn't life or death. I'll write that down in my notes as the wrong choice, buy a new unit, change my settings and move on. It really isn't that hard.
I started RC racing before most of you lot were probably born (in 1984, in fact), but I have been away from the hobby for quite some time and things have changed somewhat (now there is an understatement!). This is the reason that I am starting back in 21.5 and asking for a little advice. I will go about it the same way I always do, start with an initial setup, measure what I can, keep notes, make small adjustments and record what works and what doesn't. Hopefully I will progress, become competitive and eventually move into the quicker classes.
Old 03-28-2010, 07:36 AM   #298
Trader Rating: 10 (92%+)
this thread is about the sakura car.
if you have a question regarding gearing, and in particular speed passion, then go ask your queries in the speed passion thread. If you getting back into the sport, than go to the rookies zone thread, or radio and electronics thread.
the first reply to you was short and to the point, as no one wants to read about brushless motor gearing and esc in a thread devoted to just this one car.
captain stacker is offline   Reply With Quote
Old 03-28-2010, 08:23 AM   #299
+1
http://www.rctech.net/forum/electric...hread-236.html
Old 03-29-2010, 10:26 AM   #300
Will anyone in the us carry this car? wondering about parts support?
WEEZY is offline   Reply With Quote
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
