Old 05-04-2010, 02:07 PM   #16
Default CIAO SONO ALESSIO DALL'ITALIA VI CONSIGLIO IL MOTORE LRP SPX8-VECTOTOR CON CORONA PIG
[QUOTE = Solara; 7212370] La persona che ha il 966e sopra (dal Giappone) utilizzato Venom 50C LiPo ha detto che è possibile eseguire circa 10 minuti, però, non è una gara difficile correre ... ha detto se si tratta di corse condizione, probabilmente la più 6-7 per 4600mah.
Qualsiasi cosa più grande quindi 4.600 millimetri potrebbe non montare il caso 966e batteria. confezioni sella media 5000mAh sono almeno 31 millimetri di spessore e il caso della batteria 966e può andare bene solo 26 millimetri batterie ...[/ QUOTE]
CIAO SONO ALESSIO DALL'ITALIA VI CONSIGLIO IL MOTORE LRP SPX8-VECTOTOR CON CORONA PIGNONE 8 10 45 T TE LE LIPO VI CONSIGLIO FLIGHTMAX 5.700 IN VENDITA SU HOBBYKING
alessio966e is offline   Reply With Quote
Old 07-08-2010, 01:19 PM   #17
Greg M's Avatar
Any updates on what people are running or if the Zippy packs will fit?? I'm thinking about getting one and running Tekin, I presume the 2650kv motor would be best on 4s. I currently run 6s in by Xray 808, but can't see 6s fitting
Greg M is offline   Reply With Quote
Old 07-09-2010, 11:29 AM   #18
Trader Rating: 16 (100%+)
I doubt any 5000mah LIPO packs will fit the 966E saddle design....my 4600mah Speed Power fits perfectly (with 0.5mm space around, which is very very close). It is NOT the height of the lipo that bothers me, it is the width and lenght of the saddle packs that you have to worry about. If only just the height of the packs, you can add spacer and raise the plastic cover and will still work...but if the packs are wider and longer, nothing will work.
Old 07-09-2010, 01:23 PM   #19
Greg M's Avatar
Thanks for the reply, I had a look at the Speed Power batteries and compared against the Zippy. Looks like the Zippy are shorter, but taller, so should fit with some spacers, but next issue is body clearance. I guess when I eventually get my 966E, they are cheap enough to try, if no one else has.
Old 07-09-2010, 02:15 PM   #20
Yes. Once you raise the batteries cover...it won't fit the body...cause I know my current 909 body is BARELY sit on top of the chassis and my R8 ESC is actually rubbing against the bottom of the body. If you raise the cover, it won't fit...
Bite the bullet, get the Speed Power one or the IP or anything around 4600mah...
Old 07-11-2010, 06:16 PM   #21
KostaG's Avatar
Trader Rating: 48 (100%+)
What is the actual size of the lipo's the 966e actually fit?
Thanks.
Current Cars:
- Schumacher SX3 & Cougar SV
- Mugen MRX5 WC, Serpent 966e (4s)& Motonica P81e (6s)
Collector/Vintage Cars:
-Serpent F180 (2x), Serpent Veteq, Losi Jrx2, Tamiya Avante & Associated RC10
KostaG is offline   Reply With Quote
Old 07-21-2010, 07:39 AM   #22
I use 25mm and there is about 1-2mm gap. Using 23mm the battery case should flush with the chassis.
darmawaa is offline   Reply With Quote
Old 07-21-2010, 07:52 AM   #23
KostaG's Avatar
Thanks. Do you what the width and length would be? I am looking at buying the IP saddle packs.
Current Cars:
Old 07-21-2010, 09:23 AM   #24
69 x 46.5 mm. It fits snugly (the gap is less than 0.5 mm)
Old 08-02-2010, 07:40 PM   #25
Send a message via MSN to yellow_grey
Just wondering what kind of power setups you guys are using I.e. Motor/esc/spur/pinions etc..for your 966e
I am using the LRP SPX 8 and LRP Vector 8 2800kv using the stock spurs n pinions, and after approximate 5min run, motor is burning hot.... Have now installed the Tekin 2600kv and see what that one will be like on stock pinion and spur.
Track is parking lot, small-medium size, medium bite....
Ps I am on the IP saddles and they are slightly taller but no issues there..
Radio: Fut 14MZ, Fut 12FG, Fut 4PK, KO EX-10
Rotary - Aurora 90, Vibe90SG, TT R90SE, A TREX600N Flybarless, 500SE, 450SE
F.Wing - Spot On120, Ultimate120, Tucano90, Mustang50, Ultimate40, Piper15
Jets - Baby Boomerang Jetcat P80, Rafale Jetcat P60SE, Skyhawk A4, Velox
On/Off Road - T2'009,T3,733,S18,Atlas Beat,MiniZ4WD,XB808,ZX-1,Savage Flux, TRF511,SCX10
yellow_grey is offline   Reply With Quote
Old 08-02-2010, 08:03 PM   #26
I use castle Mamba monster 2200kV truggy/monster truck motor with 20T pinion and 4S.
Motor temp is 150F , I'll gear it more to 22T as the torque still too much.
With 22-24T I think I can keep up with 966 nitro top speed.
Use only truggy (big motor, 420+ gram with 966E). Smaller motor is just too much for 966E. LRP vector 8 is only 275 gram
The other big motor is Tekin truggy motor.
With lots of traction, 1/8 on road is much more power demanding than even 5Kg monster truck.
If you still want to use the Vector 8, use smaller pinion like 14 or 16T, but you are not use the 966E potential.
Old 08-02-2010, 11:05 PM   #27
Darmawaa,
Thanks for the response.... Well I already have the tekin 2600kv, so maybe I'll gear it down...I have a 17t pinion. Even with the LRP 2800kv, there's already soo much torque on the infield.....
Have anyone tried the hobby wing 1/8 sensored combo?
Old 08-02-2010, 11:29 PM   #28
I used the Intellect IP saddle pack 5200mah 45C, and that fits perfect.
http://www.rc-toro.com/product_info....f3295515bf0b6e
The height/thickness of this battery is 25mm and the lenght 68mm
silverM3 is offline   Reply With Quote
Old 08-02-2010, 11:38 PM   #29
Originally Posted by yellow_grey View Post
Darmawaa,
How big is the Hobby wing motor? 966E need high horsepower motor, I think 400 gram minimum.
Old 08-03-2010, 12:11 AM   #30
From their website they are around 345-385grams....
I find it rather interesting that you quote motor potential from their weight?!
What is the basis of using weight? The hobbywings are 2000kv and 2200kv motors.
Sydney Model Autosports Inc [smaracing.org] The Ideas Man Australian Racing 25433 12-14-2017 05:42 PM
Serpent 966 madbeats Nitro On-Road 2237 10-29-2014 09:08 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Brushless Serpent 966 f1bmw Nitro On-Road 51 03-06-2010 09:43 PM
