Old 04-17-2005, 12:57 PM   #871
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I'm starting to think it is because AE is concentrating more on they're RTR lines.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 04-18-2005, 06:54 AM   #872
Originally posted by Mike D
The Associated manual is misworded... check your pm.
Please send it to me too! THX
JWATT is offline   Reply With Quote
Old 04-29-2005, 08:13 AM   #873
Default sorry guys....
Sorry guys... been out of town alot... But i am back and ready to answer to the best of my knowledge... also getting ready for the Reedy touring car racing in CA.....
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 04-29-2005, 09:59 AM   #874
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Mike, can you find out the setup Barry was running at the RD Logics race for me? I've heard it was red/red w/no swaybars. If that's true I would also like to know his camber link locations and shock oil. I guess droop and shock locations too, but don't worry about the stuff like clutch springs and gearing.
Thanks man, see ya soon!
BigDogRacing is offline   Reply With Quote
Old 04-30-2005, 07:41 AM   #875
BIGDOGRACING... I was there at the race but did not really look at his car that closely... But i do know he had red springs and now sway bars.. I am sure that associated will post the setup when brent get's back.. he is away,,,, If not i will ask baker if he can post it here.. or send it to me..., .
Mike .
Old 04-30-2005, 07:43 AM   #876
howard hudson's Avatar
Default Re: sorry guys....
Mike
so Mike how did ya like the track In Hesperia Ca ?
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 04-30-2005, 08:40 AM   #877
Howard....
That track is very nice... A great group of people there running the show.. Can not wait to come back out there again and play....... I need all the rubber tire practice i can get
Mike
Old 04-30-2005, 12:19 PM   #878
Jon Williams's Avatar
Mike, YGPM.
Jon Williams is offline   Reply With Quote
Old 05-01-2005, 07:21 PM   #879
edseb's Avatar
Mike:
Do you have a gooding set up for the L4 on asphalt, medium traction, tight and stock motor? No set ups on AEs site.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-01-2005, 07:48 PM   #880
L4 outdoors.. i run 10 degree front blocks 3 degree caster .. .020 front springs trinity red stuff as dampening,,, .063 t-bar with center screw out ... trinity red stuff on dampner disk , double pink front tires size 1.70 rear tires 1.88 pink....
Hope this helps some...
Mike
Old 05-01-2005, 10:30 PM   #881
D_Ames's Avatar
Send a message via AIM to D_Ames
Mike,
I know your not an asphalt guy, but I figure since your getting ready for the Reedy race you might have an asphalt setup that works. I can't seem to get any mid corner rotation out of my car. I've played with roll center and castor, and also shock location. I can get good turn in, good on power steering (it hugs a sweeper like mad) and good exit steering with a spool but it pushes like a tank mid corner. The car turns in hard, dies mid corner, and then whips around on power out of the corner. What can I do to get more rotation?
My setup is...
Front
3,3 roll center shims
black ball studs with no washers on inside turnbuckle
silver springs
shocks all the way out on tower and arm
outside hole on steering blocks
1/8 washer under ball studs on bellcrank
two shims forward, one shim back on wheelbase
Spool
Silver swaybar
rear
silver springs
silver ball stud with 1 washer
one shim forward, two shims back on wheelbase
Silver swaybar
2 degree toe
I'm just at a loss as to what to change to get rotation. like I said, the steering is great everywhere except mid corner
D_Ames is offline   Reply With Quote
Old 05-02-2005, 11:13 AM   #882
edseb's Avatar
Thanks Mike. How bout the gearing for a monster stock pro, assuming the diameter of the foams you gave.
Carl Hyndman
Old 05-05-2005, 03:04 AM   #883
Edseb- start w/ a .98 roll out
Mike, u ever talk to Barry about hsi setup? He never gets on rctech anymore...
Old 05-06-2005, 09:33 PM   #884
D-ames.... Try taking off the sway bars first then play with washers under the front camber links we usually run .060 with a silver ball stud....
edseb no idea really.. since i do not run stock that much it would be a guess .. maybe somewhere like 33-35 100...
bigdog... no i have not...... :-( he needs to get on here more hehe....
Mike
Old 05-07-2005, 08:57 AM   #885
Hp1RaCeR's Avatar
Send a message via AIM to Hp1RaCeR
hey mike do u have any good setups for BMI tc3 rite now im running
purple/ copper 60 oil front 40 rear #2 pistons
front shock tower ( rear on front) middle hole and on the arm inner hole
rear shock tower runing on middle hole and on the arm on the outer hole
ball cups on the front runing short and low
ball cups outside long and high
5 droop front 3 rear
5 ride hite all aroud
3 degree camber rear
1 degree camber in the front
double pink orange jaco front foams
doubble pink rear jaco rear foams
its a small ozite carpet very inside track.
the rear slides a lot on thsi car i tried going down to red springs in the rear it seems that the 3 degree camber in the rear helped big time but i don't think that i should have to run that much camber.
if you could please give me a decent setup for the car today i am going to try white purple springs and 70/50 oil shooting in the dark. HELP thanx..
MIke
Hp1RaCeR is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
