Old 02-24-2005, 05:11 PM   #811
Jack Smash's Avatar
Trader Rating: 29 (100%+)
The advantage is the teflon coating on them after they are hard anodized. Smoother piston travel.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 02-24-2005, 05:17 PM   #812
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
So where as the blue ones are bare anodized aluminum, the hard anodized have a teflon coating? How long do you think the coating will last, because I'm sure it will wear off eventually?
MikeDeadly is offline   Reply With Quote
Old 02-24-2005, 05:27 PM   #813
Jack Smash's Avatar
I used to run off road and have never worn the coating off of a shock body. Used to wera the anodizing off the old gold ones though.
Old 02-24-2005, 06:21 PM   #814
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Hard anodizing will not wear off, and is much harder than regular anodizing, which is essentially for looks. I just wish I knew there were only two shocks in this "kit" before I dropped $40 on it.
[edit: I did just find out that these shocks also include the Unobtanium shock shafts, too, which could explain the large cost increase in the shock set. They should be selling over the counter for $30 a set (pair)]
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 02-24-2005, 09:48 PM   #815
Moderator
DaveVera's Avatar
DaveVera is offline   Reply With Quote
Old 02-25-2005, 12:31 AM   #816
Mike,
Do you run the batteries forward or rear on an L4. I run both stock and mod on both carpet and asphalt.
jrrc is offline   Reply With Quote
Old 02-25-2005, 04:25 PM   #817
hey mike what outdrives and cvd's do you use???
and what type of diff lube is best rebuild the diffs
thanks
travis
Jblack830 is offline   Reply With Quote
Old 02-25-2005, 04:29 PM   #818
hey mike what type of drive cups and cvd's do you use???
and what diff lube do you use and is the best to use??
thanks
travis
Old 02-26-2005, 08:07 AM   #819
bhambrent's Avatar
Mike,
I got a FT NTC3 for this year. When I was setting it up on the hudy,saw the rear wheels had play in them like the bearings were bad,but the car is new.
I'll get to the point. LOL, Blow out the bearings, put new bearing in and its still there.
Any info would be great. Long time AE racer, and never had this happen befor.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 02-27-2005, 07:52 AM   #820
Ginsu.. Not sure where to even start for a setup ? maybe a stiffer right side springs and softer lefts .. i wish i could help you more...
atom99.. Yes that is correct... As for bearing i use the associated one's no ceramics... Not sure it is really needed.. For a setup go to www.rc10.com and look at juho from the worlds....
jrrc .. I 99% of the time run the batteries back... But i did run them forward outdoors at the portland race.. So for outside give it a try.. I know it had a better balance on that track.... not more steering but just a better balance to the car...
Jblack830.... I use IRS aluminum outdrives.. IRS big dog bones
Jblack830 Stock drive cups and i use the stealth lube on my diffs
bhambrent.. Hmm maybe you got a bad set of rear blocks.. I have never had this problem. Maybe get some new one's and see or maybe the Axle is too small ?? Anyways if you do find something i would contact AE and i am sure they will listen to what you have to say...
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 02-27-2005, 07:56 AM   #821
ms2005fl's Avatar
So barry bakers carbon fiber shock towers are home made?
ms2005fl is offline   Reply With Quote
Old 02-27-2005, 09:53 AM   #822
tony montana's Avatar
Trader Rating: 66 (100%+)
Mike could you please list your snowbird setup here, I tried downloading it from associated's website but Im having problems downloading all the tc4 setups, keeps saying error on page. I will be attending my first carpet race in a long time next weekend and want a good setup. Thanks. Also anyone know were I can get the carbon kit for the tc4 at. Speedtech is out of stock
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 02-27-2005, 11:22 AM   #823
51
51's Avatar
Tony: Be sure you have Acrobat Reader 7.0. I had some problems as well until I upgraded. Hope this helps.
51 is offline   Reply With Quote
Old 02-27-2005, 11:36 AM   #824
Thanks 51 I'll try that.
Old 02-27-2005, 12:21 PM   #825
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Smile
Hey Mike,
Thank you so much for doing this for everyone - it's nice to realize pros don't forget "club" racers.
Two questions:
What is your technique for setup? I've been reading the XXX Main Setup Guide and it illustrates setup from broader, more extreme adjustments to finer adjustments. What is your method?
Also, like many, I've run into the dillema of stripped diff cases. Have a fix or suggestion?
Thanks man
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
