Old 01-11-2005, 11:29 AM   #706
TeamButter's Avatar
Send a message via AIM to TeamButter
What up Barry? I think Blackstock was running some local slow guys setup!! LOL!!!!!!
Butter
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 01-11-2005, 11:33 AM   #707
TeamButter... Now were is that man.... Yell at me sometime... mblack41266 is my aim handle...
WVRACER.... I use IRS pod plates to lower the rear axle to run smaller tires and a different top plate that do's not flex under acceleration.. Other then that everything is stock....
Doug D... I ran barry's setup at the novak race when my car was good, the other times... As for anti-dive.. Yea we run some ... And it do's exactly what is says takes some dive out of the car when entering a corner...
Barry.... Post your setup on here for all too see...
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 01-11-2005, 11:38 AM   #708
Doug D's Avatar
Trader Rating: 54 (100%+)
Mike,
Doesn't anti-dive alter caster? Where you running 4 degree blocks?
Thanks.
Doug D is offline   Reply With Quote
Old 01-11-2005, 11:39 AM   #709
WVRACER's Avatar
Send a message via AIM to WVRACER
thanks a million
Hows the tc4 comming along will we see any changes in the factory team version?
Rob
WVRACER is offline   Reply With Quote
Old 01-11-2005, 11:42 AM   #710
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Mike... Thanks... The change was way too drastic.... I can see shimming for a small change but it's rediculous.... I'm going back to the AE hubs, although the losi might be good on a low bite surface....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 01-11-2005, 11:47 AM   #711
Doug D... Yea it do's we were running 2 degree's caster and about 1/2 degree of antidive....
WVRACER.. Not sure on any changes... But we are starting to learn some stuff so we are going in the right direction...
Old 01-11-2005, 11:53 AM   #712
Doug D's Avatar
Thanks Mike!
Old 01-11-2005, 03:48 PM   #713
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Roll Center Blocks
Mike,
On the roll center blocks. I notice that the manual lists that for low roll center flat, the front is 0 and 0 but for the rear it is 2 and 2.
Can you exlain why this is? I am just curious as to why it is not the same front and rear.
Also Barry could you please post your setup, I am curious as to how your car was setup with Copper/Red springs and how it drove.
Thanks,
CRASH is offline   Reply With Quote
Old 01-13-2005, 10:23 AM   #714
WVRACER's Avatar
Mike
Mike
Is that the standard Pod or the extended
Rob
Old 01-13-2005, 10:57 AM   #715
rayhuang's Avatar
MIke-are you coming out to Practice tonight at the Gate? If you stop by-can you drive my TC4?
Thanks,
Ray
Old 01-15-2005, 03:30 PM   #716
Default Setup/Assembly
Mike,
I recently acquired a 12L3 in a trade and I am having a devil of a time getting the spur and pinion on. I am down to a 75 or 72 spur gear and still can't get a pinion on the motor. There is not enough room with nut on the tbar preventing me from moving the motor any further away. My offset is a 2 but my ride height is a little low from what I have been reading at 3.5. Do I need a different offset, remove the nut on the tbar, what do I need to do?
I notice in your setup sheets you are able to use 100 teeth spurs gears, how do you get the room?
Help!
Brad
bashbrook is offline   Reply With Quote
Old 01-15-2005, 04:42 PM   #717
Timmy Heiser's Avatar
The 100 tooth is a 64 pitch spur gear and the 72 or 75 that you are talking about is 48pitch.
The difference is that 64pitch is a finer adjustment than 48 pitch.
I will let Mike explain the rest
Tim Heiser
Timmy Heiser is offline   Reply With Quote
Old 01-15-2005, 10:21 PM   #718
I understand the difference between the 48 and 64. The reason I tried a 75 and 72 was because I they take smaller pinions. I have more smaller 48p than I do 64p pinions. I still can't figure out how to get more room back there. The pros obviously have since they run 100p spurs.
Old 01-15-2005, 11:18 PM   #719
Ohh...I'm sorry
You can also try using a lower profile nut on the center screw...But I know that when I run a 100t spur that i can usually fit a 30t pinion. Most all 1/12 drivers use 64pitch though.
What size pinion are you trying to fit?
Old 01-15-2005, 11:47 PM   #720
Hyperform Racing's Avatar
hey mike, nice job at the novak race. what top plate are you running on your 12l4?
Hyperform Racing is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
