Old 11-21-2004, 11:26 AM   #676
jc510's Avatar
Has there been a 12l4 set on this post?
jc510 is offline   Reply With Quote
Old 11-23-2004, 11:11 AM   #677
klien's Avatar
Hi! i would like to get some opinion.
i have a tc3 rtr and i am thinking of the following setup :
(hot weather, running on cocrete and asphalt)
Front:
std. shock tower
copper spring, 40wt oil,#3 piston
inner hole shock mounting, droop #6
0 camber, 0 toe
upper inner camber link
ride height 5mm
sorex tyre medium insert
Rear:
gold spring,40wt oil,#2 piston
inner hole shock mounting, droop #5
3 degree toe in, 0 camber
ride height 5.5 mm
sorex tyre medium soft insert
please advice!
Thank you
klien is offline   Reply With Quote
Old 11-23-2004, 11:32 AM   #678
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I know I'm not Mike but I would like to help you out with your setup since he might be too busy to get back to you for a few days,
The springs you have listed are a little stiff for asphalt type tracks. The stock spring setup (gold front, silver rear) is pretty good unless bite is real high, then maybe go to Red front, Blue rear. Maybe run more rear droop if you have trouble getting the rear to stick. Also, you will almost always want to run some camber. Start at 1 deg and see where the wear marks on your tires are and adjust camber to get it to wear right down the middle.
Not sure if I would run a #3 piston on asphalt but its worth a shot. Most guys would run 50wt #2 front and 30wt #2 rear to start but your setup might work on your track. Good Luck!
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 11-23-2004, 11:42 AM   #679
klien's Avatar
Thank you
Old 11-24-2004, 01:03 AM   #680
RCknight's Avatar
Default Mike....
can you use Losi XXX-S rear wheel carriers on the TC4? If not, is there anyway to do it?
RCknight is offline   Reply With Quote
Old 11-28-2004, 09:02 PM   #681
iamramos's Avatar
Default cleveland setup
please post your setup for cleveland..or starting carpet setup for foams
iamramos is offline   Reply With Quote
Old 11-29-2004, 12:03 PM   #682
Hey Mike I was wondering about your Snowbirds TC3 setup. It has it that you run two different amounts of droop on the car. It differs from left to right. Just wondering why this is. Thanks.
runnin rc10 is offline   Reply With Quote
Old 11-29-2004, 12:27 PM   #683
Vue Vang's Avatar
Mike how about that setup for tc4? Are you ready to post it yet? If not that is ok.
Vue Vang is offline   Reply With Quote
Old 11-29-2004, 12:39 PM   #684
Jack Smash's Avatar
It's to account for chassis twist.
Old 11-29-2004, 07:46 PM   #685
koabich's Avatar
Send a message via Yahoo to koabich
I think more specifically, it's to help deal with the torque steering the car has when using a really hot mod motor! This is not something to worry about when running stock or 19 turn...IMO
koabich is offline   Reply With Quote
Old 11-29-2004, 09:56 PM   #686
jayrodracer's Avatar
Default blacstock i got a ????
im running on asphalt with cs27's and im running mod and 19turn....my car is really good but i want to make it return to center quicker when exiting a corner, is it possible to do this without changing oils/springs...maybe messing with roll center or camber link length?? thank u very much...
jayrodracer is offline   Reply With Quote
Old 12-01-2004, 09:29 AM   #687
Tempest2000's Avatar
Trader Rating: 21 (100%+)
Mike,
Sorry about your luck in 12th scale. You really had a rocket ship man that thing was flying. It looked like you kept losing rear grip when you were pushing the car though???
Quick questions for you.
When you lay your servo flat what thickness washers do you put under the ballstuds to take out some of the bumpsteer? Also do you use lowered front a-arms to run smaller tires?
and your basic setup from cleveland with the 2 stage tires if you have time...
Also what rollout were you running or just what tire size on the rear and spur/pinion if you don't want to figure it up. Last question, Did you stick with the Pt for the main or did you go back to the Ti? Which one did you like better and why?
Thanks man again sorry you had a rough go of it in both classes this year I know you'll be back as always.
Thanks,
Michael
Tempest2000 is offline   Reply With Quote
Old 12-01-2004, 02:34 PM   #688
Default BlackROCK
how about that TC4 setup from the Champs..?
John Q is offline   Reply With Quote
Old 12-01-2004, 04:18 PM   #689
jc510's Avatar
Mike
What is different about your rear pod on the RC12L4?
Old 12-02-2004, 05:24 PM   #690
Send a message via AIM to gsracer
i too would like a starting point with my new tc4 just switched brands hope i did the right thing
gsracer is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
