Old 09-21-2004, 08:52 PM   #586
JohnB's Avatar
R/C Tech Charter Subscriber
I'll give that a try, thanks a bunch.
Good luck in Florida!
take care
john
JohnB is offline   Reply With Quote
Old 09-21-2004, 09:18 PM   #587
Motorman's Avatar
hey mike give me a call. I sent you a pm with the number. I will be in cali this weekend running the rd logics race so leave a number.
Dennis Richey
RD logics
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 09-27-2004, 01:35 AM   #588
peter_robinson's Avatar
Trader Rating: 21 (100%+)
hey mike, when i was scopin out your 12th ride at the nats in cleveland earlier this year, you had some grey upper links and some white (i think they were delrin, maybe im wrong) pivot balls on the front end of your car. i know you told me, but what brand were those again, and more importantly, are you still using those parts???
thanks
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 09-27-2004, 10:08 AM   #589
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Default Titanium Ball Studs on TC3?
Mike,
I had a quick question for ya about the TC3. Do you recommend getting titanium ball studs? I read that the off-road guys are putting the titanium studs with hex heads on their cars. Didnt know if it was helpful in on-road or not. Also, if it is used, what kind should I get? The only ones with hex-heads that I found are from Losi and they are different sizes than the ones used on the TC3. Any help would be appreciated.
cpatel529 is offline   Reply With Quote
Old 09-29-2004, 08:20 AM   #590
Default Re: Titanium Ball Studs on TC3?
Originally posted by cpatel529
Mike,
Titanium ball studs are probably not necessary on a tc3. They're too small to offer a significant weight difference. In terms of durability, I've never had a steel ballstud break on my tc3, but have broken one on my offroad stuff. But, if you want to spend the money, I'm sure the manufacturers have no problem.
TPJ International
071crazy is offline   Reply With Quote
Old 09-29-2004, 12:29 PM   #591
peter_robinson... The parts for the front end i got from BRP.. Not sure if he sells them still or not... But think they are dubro.. The balls are the one's off the trinity front end.. You can bascially do the same thing using a shock bottom .. Just have to cut it ..... I did this to free up the arm when it going upward.... Yes i am still using them part's....
cpatel529 .. 071crazy is correct.. There is really no need for them... I do not use them or intend too.. I have not bent a steel one yet...
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 09-29-2004, 01:33 PM   #592
rayhuang's Avatar
thanks
Peter-are you coming to the Halloween Classic in two weeks? The LHS has a ton of them in the case.
Ray
Old 09-29-2004, 07:21 PM   #593
Mike,
Robinson Racing makes Titanium ball studs. Go to their website, look in Associated section, and click on ball ends.
http://www.robinsonracing.com/
Hondaguy is offline   Reply With Quote
Old 09-30-2004, 01:59 AM   #594
Post
Hi Mike, I'm using 8T Pt Reedy with gear ratio 9.
I heard that comm drop give effect motor more faster. Is true?
What your suggestion? Trinity has some various comm drop.
imam is offline   Reply With Quote
Old 09-30-2004, 03:09 PM   #595
Default Qest about the Rc12L4?
Hi Mike,
I like to ask about different ways to "tweak/tune" the 12L4.
I wonder when and why you put grease in the damperplate?
If you use teflon-tape on the damperplate ?
What is the reason to use the thin T-bar? more or less stearing?
On bumpy track´s? to get more grip on rearwheel´s?
What is the reason to use softer spring in the front?
What do grease on the frontsprings/kingpins do to the stearing and handling of the car?
What do a harder spring on the Shock do to the car?
What is the difference between 5 degree and 10 degree suspension mount in handling of the car?
How is the change(front/back) between batteri mounts position affect the handling of the car?
How hard do you set the diff?
Here in Sweden we race on new tracks every race with 2*8min practice..The tracks is often large(Tennis court size)and 12*.wind as max
Thats why I like to understand the topic´s a little better.....
J.Winter is offline   Reply With Quote
Old 09-30-2004, 03:43 PM   #596
Chill Will's Avatar
Default Re: Re: Titanium Ball Studs on TC3?
I might have gotten a bad batch but the last time I bought Robinson ball studs they were bad. They snapped with no problem. I had one twist into when I was installing it. I would try the Losi or Lungfords. I just use the regular Losi or Associated steel ones. Never had trouble with them.
Chill Will is offline   Reply With Quote
Old 09-30-2004, 03:52 PM   #597
Default Anyone try the Titanium Racing ball studs?
They have kits and they are cheaper, but are they any good? I need the short necked ones.
Nightbreed is offline   Reply With Quote
Old 09-30-2004, 06:11 PM   #598
PW
PW's Avatar
Send a message via AIM to PW
click here http://www.racing-cars.com/usa/ Then type TC3 in the search box
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 10-02-2004, 07:55 PM   #599
Default PW, I called Schumacher and...
all I got was a spanish speaking answer machine. I wanted to talk to them about checking my Titanium Racing order for flaws. Speed Tech rep said he would deal with them until quality is back to normal.
Mike B. have you guys found a good starting setup for stock/foams on a small technical carpet track? Barry B. told me to ask you. Also does the TC4 come with plastic outdrives or lightened steel ones? Can't wait to get this thing!
__________________________________________________ __TC4
Novak Brushless
KO Propo Servos
Futaba Radios
Lunsford Titanium
Shiny MIP
RPM
Old 10-10-2004, 07:57 PM   #600
Trader Rating: 52 (100%+)
Hey Mike,
I jsut wanted to thank you again for the awesome help on set-up
and also wish you the best of luck at the worlds, hope you get to lay it down.
Mo
Mo Denton is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
