Old 07-11-2004, 05:03 PM   #451
Wency_TA03R-PRO's Avatar
Exclamation
Tnx mike and goodluck on the NAT'S race competition..... So what car/kit are you gonna use?.. FT TC3?... or RCl12
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-11-2004, 07:30 PM   #452
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
hey mike whats up? I have a question. My older brother has a Reedy Ti modified 9T motor. What pinion gear and spur gear should he run. Cause he doesn't want to burn the motor up.
Thx
TL_XXX-S_racer is offline   Reply With Quote
Old 07-11-2004, 07:51 PM   #453
Wency_TA03R-PRO.. I am going to be running a FT tc3 and the new 12L4 for this race....
TL_XXX-S_racer.. For outdoor rubber tire racing somewhere between 27-29 /100 ....
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 07-11-2004, 08:10 PM   #454
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Mike,
You said awhile ago that AE has the newer diff cases that don't need to be milled/dremeled out. But I've still heard they need a little bit of work to get really freed up. What do you think?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 07-11-2004, 08:12 PM   #455
fatbear's Avatar
Send a message via Yahoo to fatbear
Mike,
Do you run the standard chassis on the L4 or are you trying a more flexible chassis for the ashfelt tracks?
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 07-11-2004, 08:18 PM   #456
fatbear.. I have the STandard chassis and one that flex's alot more.. I am going to be doing more of a test session at this race then anything.. I am going to be testing alot of stuff for 1/12th scale so i can have the best possible combination come worlds time....
Brian McGreevy... I have done nothing to the new diff case's.. I put them on and run them without any problems.. Maybe people are shimming them wrong ?? But so far mine have been fine...
Mike
Old 07-11-2004, 08:32 PM   #457
John Tag's Avatar
Trader Rating: 42 (100%+)
Mike do you have a part # for the new diff cases
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 07-11-2004, 09:07 PM   #458
John Tag.. It is the same as the old one's .. It was a running change that they made.. I am pretty sure 99% of the new one's are them...I think they changed the mold into something were they are all the same and no wear etc..
Old 07-11-2004, 10:05 PM   #459
Thanks Mike. Good luck at the nats
USVTA Member #211
Old 07-11-2004, 11:29 PM   #460
fatbear's Avatar
Mike,
Thanks for the input on the chassis. I will be looking for your setup after this weekend. I will need all the help I can get on the 1/12th car at the worlds so I hope you don't mind me bouncing a few questions off you.
Old 07-13-2004, 08:51 AM   #461
Exclamation
Mike
ah ok.. one more question I would like to know if the differrentials on team kit tc3 out of the box are both ball diff or bevel type diff?..
If it was a ball diff you mean it uses ball diff front and rear gear set??.. If so what would be the advantage of using front and rear ball diff??.. compare to a front one-way gear set with ball diff at rear??..
Old 07-19-2004, 08:03 PM   #462
Regional Moderator
UnderDaHill's Avatar
Send a message via AIM to UnderDaHill
I was looking at some of the 1/12 scale setups you and the other top guys run and noticed that you have what looks like 6 small batteries mounted in your RC12L4.
Are those capacitors? If so, why do you use them in addition to the larger one you already had hooked to the esc?
My first guess is that they are a some sort of receiver pack.
Either way.... what is the reasoning for using them?
UnderDaHill is offline   Reply With Quote
Old 07-19-2004, 08:39 PM   #463
Is the hot new JACO tire setup for 1/12 purple front with pink rear for mod? This is for carpet.
I ask because Ive been running 19T, and it seems to be a toss up between grey and pink. They feel very similar, but the pink seems to hold up all 8 minutes, while the grey goes away. But the grey feels easier to drive in the first half.
RC Paperboy is offline   Reply With Quote
Old 07-19-2004, 09:40 PM   #464
Wency: All TC3 kits come with ball diffs
The Black Kat is offline   Reply With Quote
Old 07-19-2004, 10:22 PM   #465
Exclamation
As far as I know ball diffs that comes with the box are the stealth diffs. Im perataining to ball diffs that works on the tracks that when your car runs on corners/curves it won't decreased/slow down its acceleration/speed...
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
