Old 05-17-2004, 04:28 PM   #376
Hi Mike,
Is there a difference between changing caster on the TC3 by adding a washer under the front arm mount and changing the C-Hub? Ie, if you angle the arm mount 2* with washers, is that the same as going from a 0* to a 2* hub?
RC Paperboy is offline   Reply With Quote
Old 05-19-2004, 09:27 AM   #377
yodace .. I do not run stock that much.. So i really do not know what brush or spring to use. I would say something like a 767 brush with a purple spring.. Hoep this helps..
JohnB.. Not sure why you can not get 8 minutes with the single. that seems wierd.. But maybe there is something wrong with the motor. Go back to the double if it is going time ...
Eric Desrosiers.. seee ya next week.. I am ready ;-)
RC4SALE .. Yea i am using a turbo 35 to test my packs and some of the older one's not using the tray i was losing that amount of time . Then i got some new packs that have been used on the tray and they are staying real strong...
RC Paperboy.. I think if you put washers under the arm mounts you are doing the same thing as the f+2 . Wich would be more kickup and caster.. I think kickup and caster are similar but they do have different effects.. Try them both and let me know what you find out.. I like 0 kickup and about 4 deg caster or more...
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 05-19-2004, 09:44 AM   #378
Default Kick Up Vs Caster
ok .. heres what I have found and kinda matchs what the TC3 manual says ....
Kick up does create caster ... but by angling the arm you allow the front of the car to react to bumps and imperfections in the racing surface better ... kinda like an off road buggy with its kicked up front end ...
Caster on the other hand ... doesnt help with the bumps ... just helps the turning characteristics of the car ... how hard it turns in and how much control you have comming out of the corners
so for smooth carpet tracks and such .. you can get a more aggressive steering feel with no kick up and whatever caster setting you choose ... but then when moving outdoors to a less perfect track .. put on the f-2 front block and drop the caster block down 2* for I would guess the same feel ( sorry I dont run electric outside that much outdoors is for NITRO )
hope this helps ... enjoy racing
E
roddude65 is offline   Reply With Quote
Old 05-19-2004, 08:26 PM   #379
yodace's Avatar
R/C Tech Charter Subscriber
Mike.
Which discharge tray are u talking about about?
yodace is offline   Reply With Quote
Old 05-19-2004, 09:35 PM   #380
roddude65.. Thanks for the input.. What you said sounds about right to me...
yodace .. The new Novak discharge tray.. It works awesome ...
Mike
Old 05-20-2004, 01:54 AM   #381
johnbull's Avatar
Hi friends. Greetings from Malta.
KICK UP & CASTER.
I have been playing with these recently with interesting results.
I now have both my son's TC3 set with no kick up - front, or antisquat - rear, and the 4 degree front blocks, and it works great.
I attained this by simply adding washers at each lower end (rear of front arms and front of rear arms) to have both sets of hinge pins running parallel to the chassis.
The car seems so much more responsive.
I would like to try more front caster, say 6 or 7 degrees. Does anyone make blocks?
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 05-20-2004, 04:25 AM   #382
fatbear's Avatar
Send a message via Yahoo to fatbear
John Bull,
Try the Losi XXXS 6 degree front blocks, They work great. They are the only thing that has been able to get me around the long fast sweeping corners we have in New Zealand. I run modified on foam tires on a ashfelt track.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 05-20-2004, 06:22 AM   #383
johnbull's Avatar
Thanks fats. I think I have some in the shop.
Old 05-22-2004, 06:58 PM   #384
Default the gate
Mike,
what is the address for the Gate in Maple Heights, Ohio that you race at?
Visiting parents in Ohio, and want to stop by and check out the facility.
Thanks,
Robert
robert s is offline   Reply With Quote
Old 05-23-2004, 04:03 AM   #385
serpentracer1's Avatar
Send a message via AIM to serpentracer1
Robert S here is thier website.
http://www.clevelandcarpetracing.com
DAVE (THE SNAKE) Rasnake
Original Mimi Wong Clan. M.W.C. For Life
Associated B6D
Orion R10 Pro VST powered
serpentracer1 is offline   Reply With Quote
Old 05-23-2004, 03:01 PM   #386
UCHEATULOSE's Avatar
hey mike is it true you have some fast set-ups for nascar on-line but wont send them to your friends? lol tony and I are still waiting for those bro....put down the radio and send us something...lol [email protected]
UCHEATULOSE is offline   Reply With Quote
Old 05-24-2004, 07:10 AM   #387
UCHEATULOSE.. I sent tony some a while ago he was supposed to send them to you to try... Never heard back from him so i assumed he got them.. I do not have anything right now .. My computer blew up last week in a lightning storm. So everything is back to Sqaure one... E-mail me directly and i can get you in teh direction to where to get some good one's.
Mike
Old 05-24-2004, 09:13 AM   #388
Ouch.....
The Black Kat is offline   Reply With Quote
Old 05-24-2004, 04:59 PM   #389
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Mike,
Could you please post your setup from the Pre worlds Track. Also for 4 Cell 1/12th Roadcourse what gearing and timing should I use for a Reedy PT 8 and 9 turn Modified.
mike ivy is offline   Reply With Quote
Old 05-25-2004, 01:52 AM   #390
ringo's Avatar
Default one ways vs front diff
hey guys.
not sure if this the right forum for this, but you guys seem to know what you're talking about. i was wondering if anybody might be able to help us out with a question i have regarding one way front bearings.
i'm new to the onroad 4wd thing, and have just gotten myself a tamiya ta04 trf ssg, which runs two sets of oneways. i understand the way that the oneways work (vs front diffs), but don't understand the benefit of running them on both the layshaft and the front axle.
if anyone can explain it to us, it'd be much appreciated.
ringo is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
