Old 05-08-2004, 03:35 PM   #346
JDXray's Avatar
Send a message via AIM to JDXray
I know i am not mike but, moving the batteries closer to the shaft, makes the weight more to the center= more center of gravity.
JDXray is offline   Reply With Quote
Old 05-08-2004, 04:29 PM   #347
Mike,
I think this is the most important question I'll ask from pro guys like you.
I find my self not improvin racewise Im on a slump, Im prepared to kick bad habits( drivin) .
If you were to advice a new guy and you know he will spend time and effort
1.what will be the best Practice advice you can give?
2. w/ regards to settin whats the fastest,surest way you check your tweak in the car
3. how do you go about checkin your car durin races,coz I know there is like a semi ritual you guys do
i notice this coz some guys learn faster than others and then there are some who know nothin about setup but has talents in drivin.
Bon Ramat is offline   Reply With Quote
Old 05-08-2004, 04:39 PM   #348
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Wrong. Changing the location of the batteries laterally doesn't change the center of gravity. It moves the weight closer to the center of rotation and therefore allows the weight to shift quicker. The center of gravity will still be the same hieght and the roll moment stays the same. Transition time is the benefit, but it's not always beneficial to our cars. Look at the Pro3- it had the batteries down the center but it didn't make it faster than any other cometitive sedan. In fact, from what I understad the car was hard to tune at a national level event. I think it's track record is a good indication.
BigDogRacing is offline   Reply With Quote
Old 05-08-2004, 06:12 PM   #349
JDXray's Avatar
thanks BigDogRacing, for clearing it up for the person and myself, my bad.
Old 05-08-2004, 10:27 PM   #350
NP JD, glad to be of help. Hope I didn't cut in on Mike's thread too much- he might hit me with a gold club!!! Well, that's not gonna happen either; I'm only 34yo so I'm not old enough to play golf
Old 05-09-2004, 02:41 PM   #351
Trader Rating: 37 (100%+)
set-up/motor...
what type of gear ratio and/or rollout would you use on a 9x2 4mag mod motor on a onroad track that is 185x100ft in dimensions.....not that technical.
we run foams...so wondering what's a better starting point....a indoor foam set-up like yours from recent races or a asphault rubber tire setup like b.bakers from the reedy race....didn't find any asphault foam tire set-ups on AE's site.
thanks in advance.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-10-2004, 09:53 AM   #352
JohnB's Avatar
Originally posted by Mike Blackstock
JohnB.. Try a .075 with trinity red stuff on dampner and the front king pins with .020 springs .. Sounds like your rear dampning might have been off.. Where you using the center screw ??? Run 40 wt in the center shock with the green or silver spring you might have been too soft.. purple front tires and pink rears or whites.... Try this .. Glad you like the pt...
Mike Blackstock
Hello. Had a great race Sat. night. The car was better with stiffer dampening, but still hopping a little. I think we've determined it's the track though. I'm not the only one with the problem. Even some sedans with aggresive drivers are having problems.
I ended up with 50 wt. oil, .075 T bar w/ 3 screws, purple fronts and gray rear and an old school front end. Most importantly was just driving VERY smooth. If I accelerated smooth out of the corner I could control the hop without hurting lap times to much.
It would get a little loose the last minute and my lap times would drop about .5 sec. Must be from such a stiff setup.
take care
john
JohnB is offline   Reply With Quote
Old 05-10-2004, 09:11 PM   #353
Bon Ramat..... As for advice. PRACTICE PRACTICE PRACTICE.. Try running different setups as much as you can to learn what the car do's etc...
As for tweak . I set ride heights then set the tweak on the track. Then after i get it where i think it is correct. Then i will set it on a tweak board and see where it is then go back to that setting before each run....
Before the race i do not have a ritual . I just make sure the car feels balanced and not tweaked if possible. But nothing out of the ordinary...
Nexus.. For that motor on that size track try starting around 29-30 / 100 .. then go from there.. I would try a carpet setup for outdoors with foams. I think they will be closer to what you want then a rubber one...
JohnB.. Try running the exact setup you run with pink rears.. This will stop the traction from going away.. This seems to be all we run now...
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 05-10-2004, 09:52 PM   #354
Mike (or anyone else): I'm getting my foot in the door of Mod-Foam-Carpet (I have the outdoor curse too) I got two sets of 37-40 shores with a package I just got...What spring combo would be a good starting point? I'm having trobule translating Jaco's color code into Shore #'s so I'd like a bit of imput from an experienced hand on what springs go with these tires, 40 wt oil on carpet...
The Black Kat is offline   Reply With Quote
Old 05-11-2004, 12:25 AM   #355
fatbear's Avatar
Send a message via Yahoo to fatbear
Default Mike you have a PM
Mike you have a PM from me.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 05-11-2004, 07:27 AM   #356
What about that thing you do where you sit indian style with your hands on your knees in a toga sheet while humming very low and touching your nose with the tip of your tongue?
Old 05-11-2004, 07:36 AM   #357
The Black Kat.. Goto: http://www.rc10.com/racerhub/setup/0setups_onroad.htm Look for any of the carpet setups there and give one a try.. As for the tires i think a 37-40 shore is like a purple as long as it is not front rubber ... wich should be ok on the rear of the car but not the front.. For the front you will need a purple/orange or a double pink/orange tire anbd the rear we run double pinks or purples.. These are the codes that jaco use's..
BigDogRacing.. SHHHHH... LOL.. Now that is funny......
Mike
Old 05-11-2004, 08:36 AM   #358
johnbull's Avatar
Mike. Greetings from Malta.
Could you tell me what turn mod motors you guys were running at the Worlds warm up.
TC3s are still cleaning up out here despite almost being elligible for a pension.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 05-11-2004, 08:46 AM   #359
You guys use dual compound fronts? I just use discount rack TRC's (the old kind that come in a tube, its within budget at $6.99 a pair)
I'll start with Purple/Copper & work my way from there
Old 05-11-2004, 09:05 AM   #360
johnbull .. we were using 8X2 doubles... Glad the car is working so good for you there still...
The Black Kat .. Yea we do use combo fronts.. It makes the car drive so much easier then running with purple fronts...
See ya
Mike
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
