Old 04-26-2004, 02:05 PM   #316
Neosaka.... I charge 6-cells 6.0 amps and .02 cut off... 4-cells i charge 5.0 amps with a .02 cut off... Hope this helps.. I have not tried any of the funky reflex stuff.....
John Hughes.. When ever i ran foams outdoors here is the tires i use.. Jaco Purple orange fronts and purple rears , front and rear are 28mm wide.... As for the tire wear. I think the new surface is going to be very hard on tires for a bit until it slickens up a bit.. I ran outdoors purple Springs #3 pistons 50 in the front and 40 in the rear with copper springs.. .055 roll bar front only.. Short wheel base.. Shocks outside on the towers.. 4.5 mm ride height in the front and 5.0mm in the rear 1.5 mm up travle in the front and 1 in the rear..
As for rubber tires all i run are handout stuff now.. I do not really know if this is true.. Sorry ...
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 04-26-2004, 02:11 PM   #317
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
Default 12L4
I just picked up a 12L4 and I was wondering if you put anykind of 'lube' between the dampner plates?
Thanks!
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 04-26-2004, 02:15 PM   #318
rayhuang's Avatar
Mike-whats up w/ the newer Reedy Mod motors. I have some 2yr old handwound Ti's from Putnam that still scream, but since I bought those theres PT and KR......
Are they more powerful, driveable, more efficient, easier on brushes and comms?
I also have that Revolution 8x1 and in a sedan its so mild on bottom end.
Old 04-26-2004, 02:21 PM   #319
clinttredway.. I use teflon tape on the top plate then use Trininty red stuff for lube ...
RAY.... I like the feel of the 4 mag motor better to be honest.. I think they all run good and have good and bad points but for now the 4 mag is here to stay so we do not run the older stuff. Plus the new stuff out runs it now anyways... With running this low of winds efficiency is out the window .. I use the KR for touring and the Pt for 1/12th.. I run a turn milder then you would with a 2 mag motor ... so 8 and 10 for touring and 1/12th...
Hope this helps
Mike
Old 04-26-2004, 02:24 PM   #320
Thanks Mike!
How do you like your 12L4 compared to the L3... even though they are essentially the same car...
Old 04-26-2004, 02:31 PM   #321
rayhuang's Avatar
[i]I use the KR for touring and the Pt for 1/12th.. I run a turn milder then you would with a 2 mag motor ... so 8 and 10 for touring and 1/12th...
Hope this helps
Mike [/B]
Mike-thanks!! It sure was fun to run Modified 12th again. Hope to do it a lot more next fall. Nothing like clipping a board on power and flipping for 10'!!!!
Take care,
Ray
Old 04-26-2004, 02:34 PM   #322
clinttredway.. No problem.. I have no run the car yet.. I hope to run as soon as i get back from the pre -worlds this week...
Ray... LOL.. I hope you guys continue to run mod. It would be fun to have more then a few running on a full time basis......
Mike..
Old 04-26-2004, 02:35 PM   #323
Thumbs up Going to the Pre-Worlds..
I will answer any Question when i return.. Going to try and learn the outdoors again.. IT should be fun but i am ready for a humbling Experience.. I just need to learn everything i can from the outdoor master BAKER...
See you all
Mike
Old 04-26-2004, 02:38 PM   #324
Good luck Mike!
Old 04-26-2004, 02:39 PM   #325
Mike, Have a great time down there and make sure you get TONS of notes... I won't be able to get down to Fl till the week of Worlds...
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 04-27-2004, 11:58 AM   #326
JohnB's Avatar
Yes, if possible please post some notes on what you go through getting your 1/12 th scale hooked up on the pavement. Maybe not just what you end up but changes you make to get there.
Give 'em heck!
take care
john
JohnB is offline   Reply With Quote
Old 05-02-2004, 06:23 PM   #327
tmunno's Avatar
Mike, can you say Splash Mountain/Haunted House and Pirates ????? We stoped off at Disney after the race on the way home for some fun. See you in Oct. (plan to make a side trip that week)
Tony Munno
Munnograffix
CFX Paintworks,
tmunno is offline   Reply With Quote
Old 05-02-2004, 08:18 PM   #328
BuddyB's Avatar
Send a message via AIM to BuddyB
Mike, are you coming to the Gate this wednesday?
-Buddy B
BuddyB is offline   Reply With Quote
Old 05-05-2004, 05:20 AM   #329
fathead's Avatar
Mike, I just bought a Platinum motor for my L3 and was wondering what brush springs you run on your Platinums. We race on a long (20+ sec laps) asphalt track with a long straight and a relatively tight infield. Congrats on the 12th mod win too.
Damon
Slavich Design
fathead is online now   Reply With Quote
Old 05-05-2004, 10:40 AM   #330
Send a message via Yahoo to Doug Gaut
Mike, I have a general setup question. When running rubber tires on a high bite track and you are having traction rolling issues which is the better way to approach the situation.
1-Stiffen oil and springs to slow roll but then you are putting more pressure on the tires?
2-Soften oil and springs to let the chassis roll but take pressure off the tires and raise inner camber links to raise roll center?
3-Lower arms on the chassis to a full low roll center?
4-Raise arms on the chassis to a higher roll center so that the chassis is closer to the ground?
The car is rolling under extreme instances mid corner or during a fast direction change like in a chicane when the car rolls back the opposite directon. Any insight would be much apprectiated. No it is not on a TC3. Sorry.
Doug Gaut is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
