Old 04-18-2004, 09:49 AM   #286
mcmoney's Avatar
Hey Mike
Not sure might be going to Reedy..Not going to warm up, too busy at school....I hear you on the rubber practice....I dont run carpet that much and I run rubber alot less
Later
McMahon
mcmoney is offline   Reply With Quote
Old 04-18-2004, 04:50 PM   #287
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default TC3 setup Ozite Carpet vs Smooth Asphalt
Hi Mike
I need some help. I currently run on Ozite Carpet during the week and would like to run the same car on Asphalt during the weekend.
The carpet setup is as follows;
Front
1) Toe In 1 degree
2) Camber 2
3) Caster 4
4) Shock oil 60W, #2 piston with Yellow springs
5) Roll Bar
6) Kickup +2
7) Droop 0.5mm
Rear
1) Toe In 3 degree
2) Camber 2
3) Shock oil 60W, #2 piston with Purple springs
4) Anti Squat 2
5) Droop 1.0mm
I would like to switch to Asphalt and keep the same shock oil/piston. I hate changing oil! Everything else should be ok and easy to changeover. Can you provide a decent setup for a Stock C-Mainer with 60W/#2 pistons?
rinkrat99 is offline   Reply With Quote
Old 04-18-2004, 05:32 PM   #288
etzkev's Avatar
Send a message via AIM to etzkev
Rinkrat, do you have anything to do with the "Rink Rat" Roller hockey wheels? Just wondering.
-etzkev
etzkev is offline   Reply With Quote
Old 04-18-2004, 10:26 PM   #289
rinkrat99's Avatar
sorry no I do not
Old 04-19-2004, 07:01 AM   #290
Rinkrat... I would go to associated's web site and get this setup
http://www.rc10.com/racerhub/setup/r...eedyRaceTC.jpg
This is a good starting point for outdoors.. All you can do is try it with your oils.. I know runing that heavy of oil outdoors unless it is 100 plus degree's might make the car too loose.. With the car reacting slower.. We usually run no higher then 40 wt outdoors...
Hope this helps..
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 04-20-2004, 09:04 PM   #291
microrcdude's Avatar
Trader Rating: 70 (100%+)
Send a message via AIM to microrcdude
mike,
What cars does vicky have?
Kyle @ Top Gear Hobbies
MayorRC.com
microrcdude is offline   Reply With Quote
Old 04-20-2004, 09:42 PM   #292
microrcdude.. All associated stuff.. She is fully backed by them aswell..
Mike
Old 04-20-2004, 09:55 PM   #293
Default 12L
Mike,
I have noticed that you use a reinforced top pod plate on your 12L that has a standoff that connects to the t bar. Is this somthing you have made yourself, or is this a part that can be purchased? What effect does it have on the car?
Thanks for your time
cwolf
cwolf is offline   Reply With Quote
Old 04-20-2004, 10:01 PM   #294
cwolf.. BRP made it for me for the 12L I am pretty sure he still sells it.... I do it to stop the pod from twisting. I feel like the car accelerates better or straighter...
Mike
Old 04-20-2004, 10:33 PM   #295
Mike-
Outdoors, rubber tires, 19t, do you suggest a spool? This is specifically for the Tamiya race, I checked out your setup sheet and saw you were running one. When would you not want to run a spool on asphalt?
spyderx is offline   Reply With Quote
Old 04-20-2004, 10:37 PM   #296
spyderx.. We run a spool there because the Reedy race do's not allow one-ways.. That is the only reason we do not run one there.. As far as running one , I think there have only been a few occasions we ran a spool over a oneway outdoors, Tight track were brake's are needed or a very slick track.....
Hope this helps..
Mike
Old 04-20-2004, 11:25 PM   #297
nashrcracer's Avatar
R/C Tech Charter Subscriber
Hey Mike this was a lot easier when we use to run 12th scale up at USA raceway in Bridgeport.
What about a setup for running foam tires on pavement. The setup shows cs-27 rubber tires and I usually run pink rears and purple fronts. And tell Vicky to tell Tony I'm still working on the Cleveland video. I haven't forgotten about him.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 04-21-2004, 08:11 AM   #298
nashrcracer.. Yes USA the good old days.. Miss the heck out of that track., As for foams outside , I would run VERY close to what you run indoors on carpet, Maybe alittle softer oils but that would be it.. Maybe 50-60 #2's or close to that....
Mike
Old 04-21-2004, 08:27 AM   #299
Hi Mike,
I am looking for a good charging & discharging system.
Which would you as an experiend racer recommend?
File Type: gif pikachu.gif (708 Bytes, 132 views)
840918001 is offline   Reply With Quote
Old 04-21-2004, 01:11 PM   #300
KE4PJO's Avatar
UAs raceway, oh Yea, the good old day's. I could beat you back then, LMAO.
"If at first you don't succeed, sky diving is not for you" Unknown
"A bad day racing is still better than a good day at work" Me
KE4PJO is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
