Old 04-08-2004, 04:17 AM   #241
Mike...Thanks for the tire info. Another question though...
What are the advantages of your and Barry's servo position? I imagine you get more weight over the front axle, lower CG and lower body fitting...is that it? And with that servo placing, you shim out bump-steer with shims under the steering arm ball stud?
I read in your 2002 'Birds set-up that you ran a shim under the front t-plate ball. I know this lowers the rear roll center (minor), but it also induces roll-steer (major). In what type of circumstances do you recomend running roll-steer? and how much makes a difference?
Thanks,
Phil Matthews
pilmat is offline   Reply With Quote
Old 04-08-2004, 07:37 AM   #242
pilmat.. The reason i run the servo flat is one to get the weight down also i think this allows the car to turn alittle more with the bump steer that it makes....
I run a shim under my t-plate everywhere. Seems if i don't i do not get the car to rotate enough ...
Mike
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 04-08-2004, 02:28 PM   #243
Jay Boyd's Avatar
Mike, for mounting the servo flat do you use servo tape & put shoe goo around it for rigidity or is it all shoe goo? Thanks, Jay.
Jay Boyd is offline   Reply With Quote
Old 04-08-2004, 03:02 PM   #244
Jay Boyd.. I use servo tape then i shoo goo around it to make sure it do's not move...
Mike
Old 04-08-2004, 03:31 PM   #245
What makes your wife so fast?
Barry Baker is offline   Reply With Quote
Old 04-08-2004, 03:33 PM   #246
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
nice....
madjack is offline   Reply With Quote
Old 04-08-2004, 04:19 PM   #247
Barry ... Skillz.... :-0)
Mike
Old 04-08-2004, 04:46 PM   #248
iamramos's Avatar
Mike, For setting tweek on your car, do you do the center point lift or tweek station?
iamramos is offline   Reply With Quote
Old 04-08-2004, 06:59 PM   #249
iamramos
for my touring car i do it on the track set ride heights then adjust on the track.. For my 1/12th scale i use a tweak board that was made for me about 15 yrs ago...
Mike
Old 04-08-2004, 07:54 PM   #250
STLNLST's Avatar
Trader Rating: 21 (100%+)
Barry are we getting a cake for our birthday this year at the Reedy??? If you can't remember who this is....think tall sucka!
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-08-2004, 08:08 PM   #251
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
iamramos,
FYI...lifting the center point on a TC just allows you to see which side has more/less droop than the other. If they lift at the same time, droop is even.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-09-2004, 06:33 AM   #252
Mike...What are you using under the damper plate (stuck to the pod plate)? Is it teflon? And where do you get what you are using?
Thanks,
Phil Matthews.
Old 04-09-2004, 08:41 AM   #253
rayhuang's Avatar
Originally posted by Brian McGreevy
iamramos,
Very respectfully Brian-this is the ask MIke Blackstock thread-not the TC3 thread. PLease let Mike answer all of his questions in here.
Ray
Old 04-12-2004, 04:06 PM   #254
pilmat.. I use teflon tape i got from BRP racing.. I also use Trinity Red stuff on the plates as lube...
Mike
Old 04-12-2004, 04:24 PM   #255
Mike when are you going to part with that tweak board.
I would hate for it to disappear one day at the track
ctmazzo is offline   Reply With Quote
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
