Old 03-21-2004, 12:26 PM   #166
WVRACER's Avatar
Send a message via AIM to WVRACER
man some one needs to set up a web cam. the gate having wireless setup is such a great idea.
if some one has the know how to set up a webcam i bet that site would get a lot of hits
keep up up to date on the great one
Rob
WVRACER is offline   Reply With Quote
Old 03-21-2004, 03:01 PM   #167
wheelmanST's Avatar
Send a message via AIM to wheelmanST
Hey Mike....got a quick question. Been looking for a spool....cant find one! Does AE make one for the tc3? The only one I can find is the ntc3 one...which seems like it would be too wide. Please help me out here....if AE doesnt make one, who does? I need some part numbers!
wheelmanST is offline   Reply With Quote
Old 03-21-2004, 03:04 PM   #168
Tempest2000's Avatar
Trader Rating: 21 (100%+)
I'm not mike, but IRS makes a spool...
Tempest2000 is offline   Reply With Quote
Old 03-22-2004, 12:31 PM   #169
Thumbs up
Mike, the weather was lear as can be by the time we got to the first rest stop on the toll way...
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 03-22-2004, 03:21 PM   #170
Mike, thanks for your advise about the highways last night. I had to tippy-toe all the way to I-71 and then there were patches of heavy snow fall and ice the entire way to Columbus. After that the roads were fine, but I made it in good shape. I learned I don't have to add any droop to the suspension on my Sante Fe
davidl is offline   Reply With Quote
Old 03-22-2004, 05:10 PM   #171
wheelmanST's Avatar
Thanks Tempest2000
But I have another question....how will the alum spool hold up to using the stk cvd's? I know IRS says to use the pin cushions to keep the wear down...but how long would it last without the pin cushions? Thanks kinda why I was looking to see if AE made a steel one like the ntc3...or any other options. Thanks
Old 03-22-2004, 05:11 PM   #172
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Seth, I have one and it doesn't last more than 6-8 runs before you start getting notches in it w/ stock CVDs.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-22-2004, 05:30 PM   #173
wheelmanST's Avatar
bummer...I may just lock the steel diff instead....
Old 03-22-2004, 06:33 PM   #174
Sorry for the delay guys.. Have the nat's this week and have been real busy preparing.. I will get back to all your Questions after the race...
Thanks...
Mike...
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 03-24-2004, 01:08 PM   #175
Hey Mike I know that you are busy now!! lol lol But when you get back I wanted to ask you about an old chassis of yours. I think that I got it From Darryl!! Here in Spring Hilll TN. You had the sides milled down along with some of the webbings removed. You also took out part of the main bone down the center and had one machined and put back in to stiffin the front to rear flex. The overall bone was also milled down to match the sides. What was the reasoning behind making the car so flexible. (oh it is the composite chassis also) Thanks Matt
beanster is offline   Reply With Quote
Old 03-24-2004, 01:14 PM   #176
WVRACER's Avatar
yea Mike hope you bring another one home for team Associated
Matt was telling us on another thread that the sides was milled down when you where racing aspholt. and we all where discussing chasses flex and that this seems to cause more of it and most of us where under the asumption that this was bad
thanks for any input when you get time
Rob
Old 03-27-2004, 06:52 AM   #177
Merciless's Avatar
Send a message via ICQ to Merciless
Not sure if this the correct thread for set-up help, but if you don't mind ??
I'm just want to know if :-
Moving the rear upper shock mounting points outwards to STOP the rear inside wheel lifting while cornering is the best solution to the problem
Grip is not a problem (but i was looking to improve the set-up by stoping the lifting of that inside wheel) to be honest the set-up is very close to right
running indoors on a carpet track with foam tyres
got about(very close too) 2mm front and rear upwards shock movement only (droop)
Just looking for confirmation that my mind is working correctly really
Thanks guys
Merciless is offline   Reply With Quote
Old 03-27-2004, 07:05 AM   #178
WVRACER's Avatar
just thought i would let you know this pro is racing at the carpet nats right now he will be back after the weekend
Rob
Old 03-27-2004, 08:16 AM   #179
Thumbs up
hey Mike, hope you did well at the races this weekend!! just from your mom & dad give them hell
barbb13 is offline   Reply With Quote
Old 03-27-2004, 08:53 AM   #180
Merciless's Avatar
Thx's for letting me know
but some1 else can have ago at answering, if there sure of the answer
Please
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 07:18 PM
Where does Mike Blackstock GO next???? RCPIRATE Electric On-Road 104 07-15-2008 07:08 PM
CEFX signs Mike Blackstock Josh Cyrul Electric On-Road 39 05-17-2007 04:35 PM
Team br00d signs Mike Blackstock..... EddieO Electric On-Road 29 05-15-2007 09:24 AM
Congrats to Mike Blackstock on his move back to BIG T Tres Electric On-Road 0 10-26-2005 11:16 AM
