Which dischargers are available? >
Old 03-08-2004, 02:16 AM
Cole Trickle's Avatar
Default Which dischargers are available?
I'm looking for a discharger, with auto cut off at 5,4 volt and a discharge rate at 20-30 amps.
I'm only looking for separate dischargers, not the ones built into a charger.
I'm not interested in building a bulb discharger.
I'm knowing of the CS Cap Check Pro and Integy Reactor 20/30. Are there other choises? Preferable with a link.
Thanks.
Cole Trickle is offline
Old 03-08-2004, 04:10 AM
Deans pre-built bulb discharger is another option.
TC3er is offline
Old 03-08-2004, 11:45 AM
Lonestar's Avatar
Trader Rating: 14 (100%+)
Orion digital discharger. 20A/30A adjustable. pretty cool stuff to see exactly what's left in your pack, only disvantage is, it's got to be hooked up to 12V, and it's a rather big package.
http://www.teamorion.com/products/char_dis.asp
Later,
Paul
Lonestar is offline
Old 03-08-2004, 11:54 AM
RCGaryK's Avatar
The MPH Products Tracklight....auto cutoff, preassembled, good stuff. You can get them through B&T Batteries.
RCGaryK is offline
Old 03-08-2004, 01:18 PM
how about the new Novak one? Those any good...?
True R/C Racing is offline
Old 03-08-2004, 03:44 PM
do you have a link?
Old 03-09-2004, 04:55 AM
If you are looking for a discharger, try to get something that does a non-linier discharge (simulates driving loads) as it is much better for maintaining your packs condition.
Dragonfire is offline
Old 03-09-2004, 05:18 AM
Doesnt yokomo have one? Yokomo Rayspeed. Oh, here it is, http://www.sslorder.com/speedtechrc/39.html
Morrissey is offline
Old 03-09-2004, 07:48 AM
Thanks all.
That Orion thing could be an option. But in that case, I would save up some more to get the CS Cap Check Pro:
20 Amp pulse discharge
shows average voltage
shows discharging time in seconds
shows capacity in mAh
discharges 5-7 cells
adjustable shutoff voltage
discharge to zero function
optional PC-interface
12V supply voltage
shortcut- & crossconnection protected
CS
But both the Orion and CS is out of my budget range (at least for the moment).
So I'll probably stick with the Indy Octane 30, preferable the 20, so I can discharge a completely charged pack, without heat problems (I dont like the idea of putting a fan on the cells).
But the Indy Octane 20 is out of stock
So I'll have to see....
Between, the light diodes on the Octane, what's the purpose and how do they work?
Old 03-09-2004, 09:45 AM
RCGaryK's Avatar
do you have a link?
Here you go
MPH Products, available through B&T RC Products, www.rc-aero.com/biz/bandt (919)-471-2060
RCGaryK is offline
Old 03-09-2004, 12:47 PM
Thanks.
Old 03-09-2004, 12:48 PM
hhhhh, typo error!!! It's the Reactor, I would like to know about the diodes...
Old 03-09-2004, 01:11 PM
Tommy Bergfeldt's Avatar
I use Rayspeeds Exceed, works real good
Tommy Bergfeldt is offline
