Wat is your ride height? >
Old 03-07-2004, 10:45 PM
DT-Skyline's Avatar
Default Wat is your ride height?
I need some help guys! Can u guys give me suggestions on my cars ride height? Thanks for the posts guys.
DT-Skyline is offline
Old 03-08-2004, 01:53 AM
Default depends
It depends on the track you race on and how smooth it is anywhere between 5mm and 10mm
is good
the trick is be as close as possible without slapping the track with your chassis every 2 seconds(it creates drag and ruins the chassis)
gary
gkp5569 is offline
Old 03-08-2004, 02:07 AM
Cole Trickle's Avatar
Not to mention the low grip you gain, if the car buttoms out during cornering !
So it's better to be a little on the safe side. Usually I'm running 4-5 mm, but as said before, it depends on the track and houw stiff your suspension is.
Cole Trickle is offline
Old 03-08-2004, 04:49 AM
Depends if you're running carpet or asphalt. On carpet I'll run around 4mm outside I'll run around 5mm.
Masterfaster is offline
Old 03-08-2004, 08:05 AM
fatdoggy's Avatar
3-4 mm on carpet
4-5 on asphult
fatdoggy is offline
Old 03-08-2004, 09:24 AM
popsracer's Avatar
Default What is your ride height?
DT-Skyline;
Generally in a parking lot setting, 5mm is the norm. If the pavement has breaks in it, then 6mm may be needed to keep from bottoming out.
On a permanent type track you can get away with a little less. Usually 4mm is what's considered the allowable minimum.
Important to note, that Droop is just as or even more critical to having a good handling Car. Do NOT use the droop screws to adjust ride height (this is a common mistake). Set your ride height using the Shock Spring preload adjustments. Then adjust Droop.
popsracer is offline
Old 03-08-2004, 11:37 AM
pro3racer's Avatar
yep, i run on carpet, my ride height is always 3-3.5 mm, i run very stiff suspension too.
pro3racer is offline
Old 03-08-2004, 01:00 PM
Tommy Bergfeldt's Avatar
Swedish regulations is now 5mm as lowest.. So it's very rare i go lower than 5mm.
Tommy Bergfeldt is offline
Old 03-08-2004, 01:14 PM
pro3racer's Avatar
they don't check at the tracks i go to, lol, don't tell anyone, haha.
Old 03-08-2004, 01:55 PM
Neil Rabara's Avatar
Default Re: Wat is your ride height?
What is your car?
Neil Rabara is offline
Old 03-08-2004, 02:02 PM
If they check on carpet 5mm is the min.
A-Ko is offline
Old 03-08-2004, 07:18 PM
DT-Skyline's Avatar
Default Re: Re: Wat is your ride height?
Originally posted by Neil Rabara
What is your car?
TC3 Electric
Old 03-08-2004, 07:37 PM
MrEs's Avatar
yea 4-5mm is the best, but 5mm is the lowest legal limit. so everyone runs 5mm
MrEs is offline
Old 03-08-2004, 07:48 PM
Brian McGreevy's Avatar
4 mm for foams.
> Carpet
5 mm for rubber
Brian McGreevy is offline
Old 03-08-2004, 07:56 PM
Mr. McGreevy is correct....5mm for carpet rubber tires anything less is just asking for it
R/C Anonymous is offline
