Old 12-16-2009, 06:18 PM   #31
Originally Posted by Cain View Post
I would be curious to see if they are used with 1/12 via a booster.
No need for a booster if you are running 2s at 6.6v. We didn't use boosters with 4.8v 4 cell configuration.
On the other hand 6.6v in a 12th with current gen of bl motors and esc would be insane after the carbon fiber showers when you hit the outside wall comming off the sweeper
schurcr is offline   Reply With Quote
Old 12-17-2009, 12:11 AM   #32
Driving it in a 12th with a 9.5 and the speed is the same as mod, very driveable. Of course it could also be that I'm the next Masami but I seriously doubt that.
Its ridiculous that everybody thinks that going higher in voltage immediately means more speed, has anyone else ever thought you can also go to a higher wind motor if its too fast??
Prolly more to do with the fact that the big battery company's have invested in Lipo instead of Life's.
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 12-17-2009, 12:33 AM   #33
Now drop a 5.5 or 6.5 in it and let e know if it's still as driveable. BTW ..... 9.5 is modified. If it can be made to go faster with a shorter wind racers will do it!!!!
Old 12-17-2009, 04:00 AM   #34
GWH74's Avatar
The punch in a 1/12 scale with a 10.5 and 2S A123s is great. Does not feel as soft as a 1-cell Lipo even when using a lower turn motor with the lipo. On a very loose asphalt track as the Tekin turbo spools up it gets exciting to say the least.
Great run time. Run it for well over 12 minutes, closer to 15. Motor comes off cooler then with 1-cell.
The available energy from the 2S pack is about 15Wh (2.3A x 6.6V). SMC 4900mA 1-cell is 18Wh.
So the A123 pack has less available energy, fast as a 1-cell mod (around a 5T motor) with nearly twice the run time and less motor heat (more efficient). Fast charge them in 15 minutes, dump them to the car stops, out last the life of the car and are SAFE. Conclusion.... Two thumbs up!
hmmm 3S A123 pack in an T2 009 this could get interesting.
AE 12R5.1 - Custom chassis
For Sale BMI DB12RR, Tire Warmers and lots of other stuff.
GWH74 is offline   Reply With Quote
Old 12-17-2009, 04:20 AM   #35
Then you can tell me why in gods name I would even consider to put in a 5.5 if 9.5 is already modified.... If you're trying to find reasons not to allow 2s Life's at least come up with something realistic...
If 9.5 is too fast for you, consider 13.5, 17.5 or 21.5; at least one of these will go slow enough for you.
But nooooo, its easier to go to a lower voltage cause the other one requires some thinking of what motor you can handle.
4 cell modified is also mostly driven with 4.5 or 5.5 allthough 2.5 is also available and if they really wanted 1.5 can also be made on 4 cells.
Old 12-17-2009, 04:22 AM   #36
You're forgetting something, the A123 packs can be drivin till the car dies on the track. With Lipo's you need to keep, what is it 20% in the pack or else it goed under the required voltage. I think power output is about the same for the 2.
Old 12-17-2009, 04:40 AM   #37
GWH74's Avatar
Exactly. You can use 100% of the energy of the A123 with no fear of damaging the cells.
My main aim of playing with these cells was an option for club events. You could put a 2S pack in an old T-bar with a 27T brushed (or any cheap brused motors). The voltage is high enough to run the old brushed ESCs without boosters or receiver packs. So for $20 you can make a pay that chargers quick, last for 100s of cycles, safe and cheap for people to get into or use old equipment.
Old 12-17-2009, 09:02 AM   #38
ozvena's Avatar
ozvena is offline   Reply With Quote
Old 12-17-2009, 09:48 AM   #39
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
I did manage to confirm that the LiFePO4 tech is legal in the RC Pro series, I contact Carlton Eppes and he advised me of this and I made sure it was ok to post . From what I can tell on the description on there site, the tech just can't exceed the voltage maximums listed. Send this post to carlton just in case any issues!
The Nitro offroad rules ironically have more detail on this as they list the 1/8 electric rules there.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 12-17-2009, 09:52 AM   #40
This sounds interesting. The bigest problem I see is the same problem we have with lipo. In the lipo beginings racing lipos didn't have the energy density we have today. As soon as LiPo became the new standard and accepted under the rules the battery mfr's started push for a better battery with much higher energy densities. The same will hapen with LiPoFE, and we don't need a battery with more voltage and possibly energy density.
At this point in time onroad doesn't need another battery that has the potential for more power or a battery/motor wind restructure that could hurt on road more than it would help.
Old 12-17-2009, 09:54 AM   #41
ozvena's Avatar
Old 12-17-2009, 10:05 AM   #42
Originally Posted by ozvena View Post
I think the rules when lipo came up should have been changed. It should not be the voltage but energy stored in battery packs as a limmiting factor.
May be not, because that would require some tinkering both on the regulatory body and users. Now, you want to be successful? You download setup sheets or buy a glossy magazine, why make it harder than that? Let me tell you, the best performing RC models are not to be found there, it takes time, experience and effort to make them.
ESC are sooooo expensive because we require high current. With 4s1p setup and smaller cells like 1100mAh thinks can run light, cooler, and more efficient. Cost of ESC, packs and motors would go down too. These cells are like $5-$6 each!!! Bigger 2300mAh are like $7-$8.
I can't believe that there is no reasonable $$ amount cap in stock classes. $100 for a stock motor (LRP Vector X-12 17.5)???
I can't believe that there is such a pressure that these life cells are not considered and even banned from non-ROAR races in my local club. Why would anybody care?
ROAR hasn't banned them, at least not that I know of. There are no rules or approval process yet but to say their banned isn't necessarly correct either.
As far as the cost of the cells. Sure they're cheap right now. Theyre not mainstream for racing. As soon as they become racing cells, and the battery guys start matching they won't stay as inexpensive as they are.
There is a retail cap under ROAR rules. maybe the $90 is a relatively expensive, but racers had no problem buyinig 3-4 brushed motors @ $3O each in the brushed days. How's that any less expensive?
As far as a lot of pressure. I've never seen LiFePO on the track anywhere. Unlike the lipo movement where masses were running it before it was legal.
Don't get me wrong, I'm not against LiFePO. I can see where they have their imediate place, bashing and propably 8th electric off road. I just don't see a future for them in on road especially in pan car. We just made a battery switch that only in the last 6 months has become the accepted standard across the US and Europe. Now you wan't ROAR to change that again
Old 12-17-2009, 10:36 AM   #43
ozvena's Avatar
Old 12-17-2009, 01:14 PM   #44
Why are you comparing the motor price cap to batteries?
Ms. Sanchez has already described to you the procedure for having batteries approved by ROAR. Please begin that process, and let us know how it turns out. These batteries will not be approved because you started a thread on RC Tech.
jiml is offline   Reply With Quote
Old 12-17-2009, 01:27 PM   #45
ozvena's Avatar
