Old 06-04-2012, 03:57 PM   #151
Suspended
Smile
I run on high bite carpet, and lower roll centers works flawlessly in my tc4's.... I even hit dots while turning with no traction roll ! Each vehicle has their own magic setup for a specific driver and track condition, and it's up to you to find it....
bertrandsv87 is offline   Reply With Quote
Old 06-04-2012, 09:22 PM   #152
You definitely nailed that one. Set ups for individual driving style are very important.
I will lower my roll centers when track temps are up and traction is a little down. It really does help keep the car planted. Our spec tires are very sensitive to temperature and believe it or not I usually have a problem with them being too cold. Raising the roll center will add mechanical traction from the tires so they run a little hotter and grip better.If they are overheating I will lower the roll center to help cool them off. Amazing what 0.5 mm can do to these cars.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 06-05-2012, 07:13 AM   #153
MikeXray's Avatar
Trader Rating: 73 (100%+)
Although the theory is correct, there is nothing flawless about your TC4s handling on carpet.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 06-05-2012, 11:12 AM   #154
snuvet75's Avatar
Trader Rating: 16 (94%+)
Ok, I'm totally confused. What is traction roll? I thought it refers to sliding out of either the front or the rear. I would assume it's usually the rear that slide out at the corner that most people have problem with. OR is it that the car flips over because of G-force at the corner?? Am I wrong? If so, please correct me.
Here's my tract condition: well paved parking lot but grip is loose. It's not like having a lot of small rocks cuz the guy who runs the track blows out the track pretty well but still a lot looser than regular asphalt track(the ones that was set up strictly for RC racing). I would say the traction is medium to low.
My situation: I have T3 and it slips out on the rear from time to time. And it seems to have on power understeer. So if I'm correct on the definition of traction roll(slipping out), how should I make changes? Here's my set up:
1. Solid axle in the front, gear diff in the rear
2. Anti roll bar 1.4 in front, 1.2 in rear
3. 36 muchmore tires
4. Shock oil 350 in all four
5. Black springs
6. Front toe +1, rear -3
7. Camber -2 in front, -1.5 in the rear
8. I have every single bolts in place in upper deck except the middle one with tower.
9. Downstops: 6 in front and 5 in rear.
10. Right height: 5 in front, 5.2 in rear
11. FDR is currently at 4.03. Thinking of decreasing it to 3.8 since my competitors(I usually finish w/i the top 4) are faster on the drag racing for some reasons.
Thanks!
snuvet75 is offline   Reply With Quote
Old 06-05-2012, 11:24 AM   #155
samnelso's Avatar
Traction rolling refers to the car flipping over in the corner and barrel rolling. Sliding out is usually termed "loose" or "oversteer."
On power understeering - try less front droop. Could also try a lower front roll center, but this may exacerbate your sporadic oversteering.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 06-05-2012, 02:49 PM   #156
Suspended
Mikexray, you should have witnessed how my tc4 handled at the january 8th race Cmain, and you would understand why I say it's handling flawlessly now. I was flipping constantly!!! I even developed a specific roll and punch so I wouldn't lose too much time and get that 3rd place trophy... Now I feel confident enough to make expert in a few practice sessions, right on Coach's tail.......
Old 06-05-2012, 03:08 PM   #157
MikeXray's Avatar
5. Black springs
Thanks!
Couple quick things, first off figure out what springs, there are a few "black" springs, they have a number etched on them. I have found softer springs like 2.6F/2.4R is good in low bite.
Do you have to run 36 MM tires? if its not super hot, 32's or 28s would be a lot better.
Old 06-05-2012, 03:10 PM   #158
MikeXray's Avatar
I'm going to guess that your car is still too stiff, or no one told you to glue your sidewalls
Old 06-05-2012, 06:21 PM   #159
Suspended
My tc4 does not tration roll anymore at the speed I use to run before, but I have not tested it yet at expert class speed.... That will be next season's challenge.....
Old 06-05-2012, 06:27 PM   #160
Suspended
Smile
By the way, if I keep beating anymore Xray's with my tc4, I would have proven my point, that the tc4 is still competitive... Can't wait for next carpet season......
Old 06-05-2012, 06:32 PM   #161
Trader Rating: 41 (100%+)
Isn't that a great feeling.
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 06-05-2012, 06:51 PM   #162
Suspended
You nailed it Jd !!!!
Old 06-05-2012, 07:11 PM   #163
MikeXray's Avatar
LOL, yup xray's that can't go down the straight without hitting the boards.
Maybe you should have chosen the "red" pill.
Old 06-05-2012, 10:04 PM   #164
Suspended
Smile
They still Xray's Mike with alot more practice time then me ! If I up my practice time, I'll be ahead of M. Haynes ...lol... Not bad for a tc4 RTR 90grams overweight, unbalanced, and tweaked...... I ran it only One day with the 17.5t brushless, and started leaving folks behind in droves until I crashed.... I am not a good driver by any means, so it must be the shaft drive advantage...Hope to race (pass)you next season.....
Old 06-07-2012, 10:35 AM   #165
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
5. Black springs
Thanks!
Try lowering it. I stick to 4mm front and rear, and as described earlier, what "black" springs? Id stick to HPI silver or the MR33 reds(If you can find them...) theyre supposedly the same weight.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Traction Roll ? gansei Nitro On-Road 75 10-12-2012 12:38 AM
Traction Compounds : Health Risks : what can we do about this? Martin Crisp Electric On-Road 785 06-11-2007 03:49 PM
stopping traction rolling James605 Electric On-Road 33 04-23-2006 12:10 PM
Advice on traction rolling? Fred Perkins Electric On-Road 32 01-20-2004 03:08 PM
