Orion
Old 03-07-2004, 09:51 AM
sean's Avatar
Default Orion
anybody try the hellfire RS24 stock? i just got one and rather like it. not quite as fast but i think it has more torque than my monsters. it tends to get pretty hot though
sean is offline
Old 03-07-2004, 10:37 AM
DT-Skyline's Avatar
Is it better than the Team Orion Stock itself?
DT-Skyline is offline
Old 03-07-2004, 03:02 PM
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The Hellfire and Orion Core Stock are the same motor. They are good for smaller tighter track because, like you said, they have more torque than a Monster. It's used a lot in offroad.
Jon Kerr is offline
Old 03-07-2004, 05:03 PM
sean's Avatar
i think i am going to stick with the hellfire for a while,i might pick up a p2k2 as well. i like motors with more torque rather than top end. if it has the torque you can always gear it up a couple of teeth if you need more top end.i used to like the p2k2,but people insist that the monster is the way to go. i am not saying its a bad motor,just going to try something else for a while
sean is offline
Old 03-07-2004, 07:55 PM
Jon Kerr's Avatar
What are you running it in and what type of track? Torque is better as far as I'm concearned (sp?) because if you're able to get out of the corners faster, you should be able to get a better run onto large straights to keep up then you can kill them in the infield.
Jon Kerr is offline
Old 03-08-2004, 03:34 AM
sean's Avatar
CRC Carpet Knife and i run it at South Shore Hobbies indoor 100'x50' carpet track. it only has one straight,the rest is rather technical. it always changes though.every trophy event they change the layout right before the event.this keeps the playing field level because alot of people come from far away,if they didnt change it the locals would have an unfair advantage.its also nice to have variety
sean is offline
Old 03-08-2004, 07:57 AM
What brushes and springs are you trying? Any cuts or drill holes in the brushes?
delta420 is offline
Old 03-08-2004, 08:06 AM
rtypec's Avatar
The orion motors are similar to mvp's and behave similarly to the way you tune mvp's. Narrowing 4499 or 767 brushes and running peak/orion red springs on both sides was something we did at last year's KO grand prix. It seemed to work okay but I'm sure there are folks here with much more experience with tuning mvps than myself.
rtypec is offline
Old 03-08-2004, 08:37 AM
Jon Kerr's Avatar
What Rod said
Jon Kerr is offline
Old 03-08-2004, 09:21 AM
Excellent thanks. Are the peak reds similar to a T(caugh) red?
delta420 is offline
Old 03-08-2004, 09:35 AM
sean's Avatar
i am running the springs and brushes it came with. i havent actually started racing yet.still learning to drive 1/12.i also dont have any expierience tuning motors. i am unclear on what the effects are of softer/harder springs or different brush styles on motor performance. any pointers would be appreciated. i would like to start experimenting with motors.
thanks,sean
sean is offline
Old 03-08-2004, 09:46 AM
hobbipro's Avatar
Trader Rating: 23 (100%+)
I'm using both orion and peak stock motors, darn good motors, very good mid range torque. There's no need to drop 4-5 teeth on the pinion to gain any kind of torque like Epic's current crop. I personally like to use 4499's cut down with the stock green/red combo. They are pretty close in performance to MVP's and can be tuned in exactly the same ways. Go to www.rccars.com to get tuning tips from Big Jim.
hobbipro is offline
Old 03-08-2004, 10:02 AM
rtypec's Avatar
what hobbipro says
I'm not sure if the Peak/Orion Reds are the same as the T ones. I mooched the springs from a team driver and after the race I gave my handout motor away so I don't know.
rtypec is offline
Old 03-10-2004, 08:55 PM
Hey guys,
Joe Pillars recomended their Enduro Brushes and Green Springs on both sides... I prefer this spring combo with 766's
I really like reedy 766's and Purple Trinity Springs on both sides
I have only ran these motors in offroad but I am sure they will fly in onroad...
The purple spring combo is insane...
ultragraffics is offline
