R2 vs Yokomo SD
Old 03-07-2004, 12:40 AM
MugenMTX3Kid's Avatar
Default R2 vs Yokomo SD
OK, from Tamiya TB Evo 3, HPI PRO 4, Yokomo SD.. it comes down to R2 and Yok SD. Which one do you guys prefer? Which is more durable (crashes).. Also i run asphalt.
Thanks for the help.
MugenMTX3Kid is offline
Old 03-07-2004, 01:19 AM
ive heard the Yokomo breaks easily and parts support isnt the greatest in the world...weve had a couple guys run the Yokomo at my local track and it was hard getting parts i believe...i own an R2 and happen to like it alot the only part i have broken is the front spindle carrier...parts support is pretty good from speedtech id get what you think you would enjoy more and go from there...both cars have the potential to be as fast as any other car out there
R/C Anonymous is offline
Old 03-07-2004, 09:28 AM
Matt Howard's Avatar
The only time you'll have problems getting yokomo parts is when your hobby shop doesn't order them, They're available.
Matt Howard is offline
Old 03-07-2004, 01:00 PM
Sleighty's Avatar
I have an SD and to be honest i cant say a bad thing about it. (touch wood) I have driven an R2 and I found it to be almost the same although it broke a few times when my friend ran it on carpet.
Sleighty
Sleighty is offline
Old 03-07-2004, 01:17 PM
DOMOisCOOL's Avatar
Get the R2!
DOMOisCOOL is offline
Old 03-07-2004, 02:36 PM
JusBox's Avatar
Another vote for the R2. I had an SD and to me, the R2 is easier to work on and definately more durable.
JusBox is offline
Old 03-07-2004, 02:43 PM
lowline's Avatar
R2 we have a few guys run the yoke at home and they have pretty much sold out steering block very fragile,hub carrier.
lowline is offline
Old 03-07-2004, 05:47 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I LOVE VS THREADS!
Randy Caster is offline
Old 03-07-2004, 05:48 PM
Anyone know what pinion i should use on the stock R2 spur if i use a Reedy KR 10x2 and or Trinity Green Machine 3 Pro?
Old 03-07-2004, 06:57 PM
DOMOisCOOL's Avatar
Originally posted by Randman
I LOVE VS THREADS!
Old 03-07-2004, 07:24 PM
Dude that all depends On track too
True R/C Racing is offline
Old 03-07-2004, 07:28 PM
DOMOisCOOL's Avatar
Its a small tight track with a 20-30 ft straight.
Old 03-07-2004, 07:29 PM
i dun haev that car. whats final drive? 48 pitch// What teeth?
Old 03-07-2004, 08:08 PM
rtypec's Avatar
If you have to ask where to gear a 10x2, perhaps you shouldn't be running it just kidding. It all depends on the track, if it's a tight track, or if it's wide open...If it helps, I've run Kr10's at TA and we'd gear them around 7.8-8.2. Of course the motor would be done after that run but that's what a comm lath is for and I am still kind of a newbie with mod motors too
rtypec is offline
Old 03-07-2004, 09:26 PM
edseb's Avatar
I love my SD. From what I understand, the R2 takes a while to get tweked right. Once its up to speed, its a matter of personal taste.
edseb is offline
