TC5 (or other) set-up clarification >
Old 12-13-2009, 09:21 PM
Trader Rating: 20 (100%+)
Default TC5 (or other) set-up clarification
I am going through and making changes from the TC5R set-up sheet that came with the kit instructions to one that is more geared towards my driving conditions. On the set-up sheet that I am converting to is from Keven Hebert and the International Indoor Championship in LV. My question is in regards to bumpsteer. I am unclear on what this really is. On the original kit settings it says "Silver + 0" on the Hebert set-up sheet it says "2mm". I am at a lost as these settings seem no where near related to each other. Any thoughts, clarifications, etc are much appreciated and thank you in advance.
storytyme is offline
Old 12-13-2009, 09:29 PM
geeunit1014's Avatar
Trader Rating: 14 (100%+)
The "silver" referrers to the silver ballstud associated makes (instead of the black) that has a longer neck. The +2mm referrers to a 2mm shim being under that ballstud. If there is no reference to which ballstud, it most likely means the black.
geeunit1014 is offline
Old 12-13-2009, 09:31 PM
So 2mm would be the black ballstud with a 2mm shim? Thanks for the quick explanation.
Old 12-13-2009, 10:04 PM
Yup, thats it
Old 12-14-2009, 09:44 AM
John_S's Avatar
Bump steer refers to the angle of toe the front wheel has under suspension compression. IE if you push down on the car the front wheels gain toe in/ out etc
John_S is offline
Old 12-14-2009, 09:54 AM
Rick Hohwart's Avatar
While we are at it, the setup for droop will list a number derived from the AE droop gauge. The measurement is generally (Levanen, Hebert, Hohwart setup sheets) taken at the suspension arm under the outer hinge pin. It is not taken at the hub carrier or caster block.
Rick Hohwart is offline
Old 12-14-2009, 10:45 AM
Redwood's Avatar
Cheers Rick, I was taking it from under the lowest part (caster block), glad I got that clarified.
Regards
Neal
Redwood is offline
