Brushless V1RRR WCE >
Brushless V1RRR WCE
Brushless V1RRR WCE
Old 12-11-2009, 03:59 PM
performula's Avatar
Default Brushless V1RRR WCE
The question isn't how. Fabrication isn't the issue, at least, not yet. Or maybe it is now I think about it. I'm guessing I could use the stock gearing? There are some new spurs/pinions I have laying around - I think I bought Kyosho's whole gear range for the RRR WCE.
What size motor would I use? And how about gearing? My math isn't on par for a gear ratio chart. Single speed obviously.
This holiday season I've been looking at buying a new car (off-road) but my poor WCE has two days of racing on it, if that. maybe a little project is needed...
performula is offline
Old 12-11-2009, 04:04 PM
tom_chang79's Avatar
Were you answering someone? I didn't understand your post...
If you're talking about off-road, you should post it in the off-road section?
Just a suggestion...
tom_chang79 is offline
Old 12-11-2009, 04:17 PM
performula's Avatar
Hahaha, no! I should have made myself more clear, as I was excited, during the start of my thread.
I want to convert my Kyosho V1RRR WCE to brushless!
Old 12-11-2009, 04:39 PM
Raman's Avatar
Trader Rating: 72 (100%+)
Curious .... Why convert an RRR to brushless when 1/10 scale onroads already exist? I see the appeal for 1/8 scale buggy, truggy and on road....
Anyways, different strokes for different folks.. It's a hobby and a project right ?
you'll need to figure out your final drive ratio and match that with a motors specs. For instance I have a Novak 3.5 GTB velocity, and Novak advises final drive greater than 9.5. If you go with an 8.5 motor than you can go lower etc.
Raman is offline
Old 12-11-2009, 05:29 PM
performula's Avatar
You're right. Are there 200mm cars?
Oh well I took it apart an cleaned it.
Old 12-11-2009, 05:35 PM
Raman's Avatar
Kyosho just released the EP Fazer series which are 200 mm electric TC cars. You can also run 190 mm with + offset wheels to get to 200 mm..
Raman is offline
Old 12-11-2009, 05:37 PM
performula's Avatar
Raman, also, I've been a nitro guy since '99 and haven't raced since '06. Call me ignorant, I have no clue what's going on these days other than brushless.
Plus, this car just sits, it's a shame. It probably isn't worth a dime as it's two generations old. Plus I have all the Kyosho upgrades for it still in package. It's just a waste.
But, I'm tired of getting greased up and cleaning grime. Not that it goes away, but electric was so much cleaner.
Old 12-11-2009, 05:46 PM
performula's Avatar
I wish Mugen would make one. While Kyosho makes winners, there's something about the plastic/nylon composite (?) I don't like. If I remember correctly, my MTX3 was entirely nylon composite, or at least felt stiffer/sturdier. Down to the linkages...
Anyway, guess I should go now.
