HEX SPACING......? >
HEX SPACING......?
HEX SPACING......?
Old 12-10-2009, 01:24 PM
Trader Rating: 20 (100%+)
Default HEX SPACING......?
So my quest to completely understand my TC5R set-up continues. What is exactly hex spacing and what purpose does it serve? Adive is appreciated in advance.
storytyme is offline
Old 12-10-2009, 01:33 PM
LOW ET's Avatar
Trader Rating: 103 (100%+)
hex spacing as refered to from the tc5 setup sheet is just a shim, washer, or spacer that goes on the axle between the hex drive and the wheel. this is what i and others use, http://www3.towerhobbies.com/cgi-bin...?&I=LXFSD2&P=7
LOW ET is offline
Old 12-10-2009, 02:36 PM
PitNamedGordie's Avatar
It's used to adjust the track width of the car.
This is taken from the Xray setup book which explains it a little:
Front track-width
Wider
Decreases front grip.
Increases understeer.
Slower steering response.
Use to avoid traction rolling.
Narrower
Increases front grip.
Decreases understeer.
Faster steering response.
Rear track-width
Wider
Increases rear grip at corner entry.
Increases high-speed on-throttle steering.
Narrower
Increases grip at corner exit.
Increases high-speed understeer.
Increases front grip in hairpin turns.
PitNamedGordie is offline
