TOTAL TOE???
Old 12-09-2009, 10:52 PM
Trader Rating: 20 (100%+)
Default TOTAL TOE???
Just need a quick answer. What is total toe. I understand toe in and toe out, but don't want to search for "total toe". Just need a straight forward answer. Thank you in advance.
storytyme is offline
Old 12-10-2009, 12:05 AM
Ryan Maker's Avatar
Total Toe usually refers to Inboard Toe + Outboard Toe.
Inboard toe being the angle that is produced by the whole Suspension arm and Outboard being the angle produced by the outer Hub.
Most cars these days come with 3 Deg Inboard toe and 0 Deg Outboard toe on the Rear and 0 Deg Inboard toe and adjustable (With Turnbuckles) Outboard toe on the front.
Hope this makes sense.
Ryan.
Ryan Maker is offline
Old 12-10-2009, 12:16 AM
Ryan.
hey thanks for the explantion, Ive been wondering about this as well
Ive a couple of questions on this topic as well..
so a 'hopup' 3 degree hub would be a outboard toe adjustment?
The total toe is the one we measure with setup stations ?
Does it matter whether the total toe is produced from inboard or outboard??
1101 is offline
Old 12-10-2009, 04:57 AM
Jackster's Avatar
Trader Rating: 19 (100%+)
But you can't adjust toe with the hubs, correct? Are you just referring to to angle at which they mount to the arm?
Jackster is offline
Old 12-10-2009, 06:41 AM
Ryan.
You can adjust the toe on the rear with turnbuckles as well right? So the inboard toe is established when you build the car and install a certain shim to create that toe? and then you adjust the turnbuckles to get to the desired total toe?
Old 12-10-2009, 06:52 AM
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Since were on the topic,
how do people feel about outboard rear toe giving more rotation?
Owen RaCing is offline
Old 12-10-2009, 06:56 AM
Company Representative
SweepRacingUSA's Avatar
I dont know what car you drive but as far as I know there is no electric TC that you can adjust rear toes with a turnbuckle.
only car that I remember is org version NTC3, and thats a gas car.
turnbuckles on the rear adjust the camber.
SweepRacingUSA is offline
Old 12-10-2009, 06:58 AM
trerc's Avatar
Trader Rating: 89 (100%+)
Or possibly too much rotation, outboard toe in the rear would also make the car very unstable and hard to drive.
trerc is offline
Old 12-10-2009, 07:01 AM
mtbboy's Avatar
Originally Posted by da_John_wee View Post
I dont know what car you drive but as far as I know there is no electric TC that you can adjust toes with a turnbuckle.
+1
mtbboy is offline
Old 12-10-2009, 08:09 AM
Regional Moderator
CarbonJoe's Avatar
Yes, you measure total toe with a setup station.
Hubs are outboard toe adjustments.
Several schools of though on inboard vs. outboard toe being better. Some feel that inboard toe (shims) can cause binding in the pivot pin/arm, since the pin holders are slightly cocked when tightened against the bulkhead. Thus, some prefer outboard toe.
CarbonJoe is offline
Old 12-10-2009, 08:11 AM
303slowdown's Avatar
Trader Rating: 24 (100%+)
fyi-schumacher axis 2 had rear turn buckles for toe adjustment
303slowdown is offline
Old 12-10-2009, 08:14 AM
Mark506's Avatar
Trader Rating: 42 (100%+)
Quick question, 2 degrees of inward toe in the rear, and .5 degrees of toe out in the front;
Would that make the car pretty much the same as 2.5 degrees in the the rear, and 0 in the front? I'm pretty sure the answer is no, but im just curious if that blanaces out anything
Mark506 is offline
Old 12-10-2009, 08:33 AM
I was looking on a pro driver set-up sheet for the TC5 and they had 3 for total toe in the rear. I assume this is positive 3 which would be toe out in the rear? I would think -3 degree would be the correct setting? Also, you cannot adjust the rear outboard toe with a turnbuckle (my bad).
Old 12-10-2009, 08:41 AM
Regional Moderator
CarbonJoe's Avatar
Nobody that I've seen runs toe out in the rear. It is 3 degrees toe in.
Old 12-10-2009, 08:55 AM
no, you dont deduct fr to rear or rear to front.
both front toe and rear toe does have effect on car's handling (set up) but no direct connection between it.
