Old 12-10-2009, 11:08 AM   #16
Trader Rating: 20 (100%+)
Everyone has been really helpful. If I have the RPM toe tool and camber guage, plus ride/droop guage am I good for a poor man's basic set-up station?
storytyme is offline   Reply With Quote
Old 12-10-2009, 02:35 PM   #17
Jackster's Avatar
Trader Rating: 19 (100%+)
Can someone please tell me how you adjust toe using the hubs?!! I'm still just as confused as I was in my first post to this thread.
Jackster is offline   Reply With Quote
Old 12-10-2009, 02:50 PM   #18
Company Representative
SweepRacingUSA's Avatar
on your Avid you change this part, diffrent numbers should be available.
SweepRacingUSA is offline   Reply With Quote
Old 12-10-2009, 02:51 PM   #19
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
haha, No Worries.
On the rear, Car companies make different Degree hubs. So Xray make 1 deg and 2 deg option rear hubs. This is built in suspension pin angle into the hub, and cannot be adjusted.
So the only way you can alter the rear outboard toe is to change between hubs.
Hope this helps, if anyone has any more questions just let me know.
Ryan.
Awesomatix - Muchmore - Protoform - Silverback - Radtec - LeeSpeed - Hiro Seiko - SG PitDesign - Plaig
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Old 12-10-2009, 03:02 PM   #20
Jackster's Avatar
I thought those only affected camber and/or caster....
Old 12-10-2009, 03:08 PM   #21
number showing on that hub is your outter hinge toe, not an castor. castor adjust by the block that goes under your arm mounts, of cos tierod adjust your static camber.
Old 12-10-2009, 03:11 PM   #22
Jackster's Avatar
Are you guys saying that the only thing the c hubs affect is the outer hinge toe? They don't affect the camber?
Old 12-10-2009, 03:11 PM   #23
HarryN's Avatar
Send a message via AIM to HarryN
hey Jack,
I can help you out with that.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 12-10-2009, 03:24 PM   #24
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
C Hubs are only used in the front of your car and can affect caster and camber. The rear hubs can affect outer toe (and of course total rear toe) and camber.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-10-2009, 03:30 PM   #25
Jackster's Avatar
I was getting the c hubs and the hub carriers confused. Nevermind, I solved my own problem. I just did a little googling. I guess for those of you who were saying hubs, that you meant hub carrier. That is part of what confused me.
Old 12-11-2009, 07:02 AM   #26
Skiddins's Avatar
For those still a little confused;
Rear Hubs;
Front 'C' Hubs;
Which hold the steering knuckles
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-11-2009, 09:27 AM   #27
getpip's Avatar
Originally Posted by Mark506 View Post
Quick question, 2 degrees of inward toe in the rear, and .5 degrees of toe out in the front;
Would that make the car pretty much the same as 2.5 degrees in the the rear, and 0 in the front? I'm pretty sure the answer is no, but im just curious if that blanaces out anything
Front and rear toe are completely independent.
If you hear somebody refer to 'total toe' in the front then they are refering to left plus right ... ie. 1degree left plus 1degree right equals a total front toe of two degrees.
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
******B4/T4 users look inside!!! 4* toe rear squat blocks****** chedda bob R/C Items: For Sale/Trade 161 05-11-2010 10:29 AM
****Mugen MBX5T Prospec Total Package**** jdyarb R/C Items: For Sale/Trade 8 06-08-2007 02:41 PM
Brushless ESC's and Motors - a total joke cannon Australian Racing 178 06-30-2006 06:36 AM
