set-up questions????? >
Old 12-09-2009, 10:46 AM
Trader Rating: 20 (100%+)
Default set-up questions?????
Is there a way to go to get a complete set-up station that can do it all in both touring car and off-road. Like most drivers I have moved inside for the winter, but when I build my new car this spring I would like to have a set-up station that can work for both. Which brand? I have to take out a loan to buy Hudy set-up is there a just as good brand? Anyone have one for sale? Just lots of questions? All help thank you in advance.
storytyme is offline
Old 12-09-2009, 02:15 PM
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Do yourself a favor, and get the Hudy. Yes, it is expensive, but it is extremely high quality. Mine is many years old now, and aside from scratches on the case it still looks and operates brand new. Having had an Integy one, just get the Hudy.
In the meantime, you can pick up an RPM camber gauge on the cheap and it works fairly well for setting camber, and any old ride height gauge can be used for ride height/droop.
geeunit1014 is offline
Old 12-14-2009, 02:52 AM
Toh WL's Avatar
You can't go wrong with Hudy. I used SpeedMind in comparision. Surprisingly the setup from Hudy is much accurate.
Toh WL is offline
