Losi Type R need help gearing for 17.5 >
Old 12-09-2009, 06:42 AM
salteen's Avatar
Trader Rating: 89 (97%+)
Default Losi Type R need help gearing for 17.5
I need some help. I'm putting together a Losi Type R for 17.5 rubber tire carpet racing and have no idea where to begin with gearing.
The manual doesn't go down to 17.5 in its gear chart so I went off of the suggested rollouts for 27 turn stock and I'm assuming I want something between 27 and 30mm rollout?
I'm picking up some gears today and thinking I should gear is 28/128 (64p) for a 28.97 rollout. Am I on the right track here?
I'm running a Tekin RS, and a Tekin Redline 17.5
salteen is offline
Old 12-09-2009, 06:53 AM
Troy1x's Avatar
You are way too high on your FDR. Depending on your track with a JRX-S you should be between 4.5-5.0 fdr with a tekin rs. A 120/44 will put you close to 5.0, id start there depending on your Track.
I run a JRX-S Type R with a Tekin RS and I am usually around 4.5-4.8 fdr for a small indoor track.
-Troy
Troy1x is offline
Old 12-09-2009, 06:56 AM
salteen's Avatar
Oh wow I was def way off. Thanks Troy.
salteen is offline
Old 12-09-2009, 08:43 AM
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
I'm on a 100x50 track geared at ~5.25, Tekin RS w/ Novak Ballistic 17.5, N on the motor, max timing on RS, max turbo on RS, 0.3 delay .....our track has no long infield sections, so that short delay isn't heating the motor up too much.
Greg Sharpe is offline
