-   -   TRF415 setup (https://www.rctech.net/forum/electric-road/350352-trf415-setup.html)
rwmjd007 12-09-2009 05:14 AM
TRF415 setup
Hey
I am new to racing and have got myself a trf415msx. With this i will be race 540 silver can to start off with. What is a good setup for my car. The track is mainly chicanes with 2 straights about 6 - 10 meters and a few sweeping corners.
Cheers
Robert
TwoTone 12-09-2009 06:09 AM
Originally Posted by rwmjd007 (Post 6696716)
Hey
Cheers
Robert
This is a really good site for 415 info
http://www.thard.co.uk/viewforum.php?f=11
http://www.thard.co.uk/415/setups/
http://www.thard.co.uk/415/tips/
pinggoy 12-09-2009 08:42 AM
i assume its asphalt right? im running msx right now and its doing pretty good. 170ft straight away with lots of high speed corners. i will post later after practice my setup if it will do good...
rwmjd007 12-09-2009 04:02 PM
1 Attachment(s)
Thanks for your response. I have a few questions about the on http://www.thard.co.uk/415/setups/. With there setups on asphalt why is it they run a spool instead of a one way. Do you get better breaking or traction with the spool?
Also with some of the setup sheets i am a bit confused, cause i looked at a couple Marc Rheinard did and for the diff it says direct. I am assuming that this means spool diff, am i correct?
I have found a photo of the track i will be running at if it helps.
regards
robert
TwoTone 12-09-2009 07:25 PM
regards
robert
Normally Spool outdoor asphalt and one way indoor carpet
rwmjd007 12-09-2009 07:41 PM
could you use a 1 way outdoors or is it better to run the spool.
mild seven 12-09-2009 07:43 PM
for 540 silvercan a oneway would be fine.
dodo 12-09-2009 07:44 PM
regards
robert
for me personally, with front oneway you will get higher cornering speed. IMHO it will really help if you run 540 silvercan. spool are easier to drive especially with the modified brushless motors. however oneway requires a smoother acceleration.
yes you're right, direct = spool
if i were you, with 540 silvercan and if the track has fairly good grip. i'd opt for front oneway.
but that's just my personal preference ;)
rwmjd007 12-09-2009 10:35 PM
i will try both and pick the one i like better. I also look forward to seeing your setup pinggoy.
rwmjd007 12-09-2009 10:50 PM
Also will i need a high speed steering servo?
dodo 12-10-2009 02:31 AM
if you're not on a tight budget, getting it will be a good investment IMHO
rwmjd007 12-10-2009 02:35 AM
ok cool i have a spare one from my drift car. sorry have not been totally honest. i have been drifting for 5 months and now have a second car that i am going to go racing with. so thought i would start with 540 and can always move up from there.
tc3team 12-10-2009 02:39 AM
On a big track, ive used a centre one way with 2 diff's with a 27t motor and I really liked it :nod:
It is a bit more subtle than the front one way too, so you have a little more braking. not by much but it can help sometimes.
Just another thing to consider trying.... :):tire:
rwmjd007 12-10-2009 03:37 AM
i will have to try that as well. it sounds like i will have to spend a few days at the track testing different diffs. Also with this http://www.thard.co.uk/415/setups/CLewis415Reedy06.jpg setup sheet it says that the front axle is 4 degs what does this mean?
TwoTone 12-10-2009 05:59 AM
Not to hijack the thread, but how do you think that set up would work for VTA indoor carpet? I've been tempted to try it out.
My driving style just doesn't seem to work with one ways.
