VFS2000 Wiring
Old 03-04-2004, 07:10 PM
Shayd's Avatar
Default VFS2000 Wiring
Hi folks,
Just bought a used Ko Propo VFS2000 and wanted to check and make sure I am wiring it up right.
looking at it with the wire posts to the right side here is what I think they are, please tell me if I'm wrong:
top right: Battery Ground
mid right: Motor Ground
bot right: Battery Positive & Motor Positive
Is that right?
Thanks,
Scott
Shayd is offline
Old 03-04-2004, 10:00 PM
PizzaDude's Avatar
Yould better go to the VFS2000 thread which is allready here.
Good luck.
PizzaDude is offline
Old 03-04-2004, 10:06 PM
RCTech Member #2
TSR6's Avatar
http://www.rctech.net/forum/attachme...?postid=731825
picture:
If you look real close, I think it's even printed on the PC board in small letters.
TSR6 is offline
Old 03-04-2004, 10:55 PM
Shayd's Avatar
Thanks, I had looked on the case and quickly on the PCB but didn't see anything.
Scott
Shayd is offline
Old 03-05-2004, 09:41 AM
rc-zombies's Avatar
Scott
you'll need a magifying glass to find it...
with the solder tabs facing right
wiring goes like this
top tab: neg on the batter
center tab: neg on motor
bottom tab: pos on motor / batter
you had it correct on your first post...
I highly recommend you getting the PC interface...make programming alot easier than the handheld unit...
good luck..
rc-zombies is offline
Old 03-05-2004, 09:48 AM
Regional Moderator
here you go
Ko Racer is offline
Old 03-05-2004, 10:03 AM
Shayd's Avatar
thanks guys for your responses.
Much appreciated.
Scott
Shayd is offline
