Tamiya TT-01 parts >
Tamiya TT-01 parts
Tamiya TT-01 parts
Old 12-07-2009, 01:50 AM
Default Tamiya TT-01 parts
1. What is a good brushless motor/esc for $75-150?
2. Is it ok to run a brushless system in their stock setup?
If not, what is the best bushed motor for the same money?
3. Where can I get deep dish wheels?
Thanks for any and all info in advance.
smokinmaxx is offline
Old 12-07-2009, 04:03 AM
PaPeRo's Avatar
http://www.hobbypartz.com/ezrun-35a-9t-3650-motor.html
PaPeRo is offline
Old 12-07-2009, 09:14 PM
Thanks PaPeRo,
Anybody else?
Old 12-09-2009, 12:11 AM
PaPeRo's Avatar
You're welcome, make sure you upgrade the plastic drive shaft to a metal/aluminum one. The stock plastic one will warp under high rpm from the brushless motor. Also make sure your car has a full set of ball bearings installed.
PaPeRo is offline
Old 12-09-2009, 01:01 AM
If you can afford it go brushless. The EZrun is really good value: i have 3 in different cars. There are better but you'd have to spend big $$$ to get a better system.
I honestly wouldnt spend big money on a TT01, or spend too much on upgrades. You can easily end up spending far more than the car is ever worth & a TA05 or TB03 would have been cheaper. The EZrun is still a good choice for that car though.
A metal driveshaft & bearing kit, 2degree rear hubs are all you need for now.
Perhaps a harder metal pinion than the standard one as well.
And some good tyres.
Brushed motors can be a bit of a pain. The motors need rebuilding too often: its cheap & easy but just a pain in the A. You need to find a shop with a comm lathe.
You can find anything on ebay, if you live in the US then you're in parts heaven compared to some other countries.
1101 is offline
Old 12-09-2009, 10:07 AM
Thanks 1101. Actually what I'm really wanting to do is just buy the TT-01 bathtub because I know in the long run I'll end up ugrading everything to the Tamiya blue anodized aluminum parts anyway. I thought about the carbon fiber tub but there's no point in that for me. It's only theoretically useful for comps and I don't plan on doing any. It'd just get scratched to H.
