Old 12-15-2009, 06:14 PM   #16
simplechamp's Avatar
Trader Rating: 73 (100%+)
I don't see the point of a built-in cut-off. So if you want to buy multiple packs each time you are paying extra for the cut-off, when you really could buy normal packs and a single external cut-off. And then what do you do if the pack dies or cut-off dies, replace both pieces even though one part is still fine? And then when you upgrade your ESC to one that has a cut-off already what happens there? Do you use the one in the lipo pack or the one in the ESC. Just doesn't seem very effective or useful in the design.
Originally Posted by jmackani View Post
The C (discharge rate) really does not matter if you are not running brushless.
Yes it does. Regardless of brushed or brushless motor you still need a battery that can deliver enough current. If your brushed motor is drawing 50A and your battery can only deliver 40A (4000mah 10C pack for example) that's a problem. C-Rating matters either way.
simplechamp is offline   Reply With Quote
Old 12-18-2009, 04:15 PM   #17
drive2survive's Avatar
Trader Rating: 23 (100%+)
Ha, bought these paks for a good price! and they are good for so many laps, ya just gotta figure out how long in diffrent circumstances, I like the internal shutoff, just one more thing ya dont have to worry about, so far they proved to be just fine
"OLD MUSICIANS NEVER DIE, THEY JUST DE-COMPOSE"
drive2survive is offline   Reply With Quote
Old 12-18-2009, 11:19 PM   #18
which packs did you buy? packs with lipo cutoff would be perfect for people who do not have a esc with a lipo cutoff right?
djr53 is offline   Reply With Quote
