charging Li-Fe 6.6v reciver pack 1/12 ?? >
Old 12-04-2009, 03:24 PM
Default charging Li-Fe 6.6v reciver pack 1/12 ??
I did buy a Li-Fe 6.6v 200mah reciever pack for 1s li-po in 1/12. I have problem with chargin the pack, does anyone now how to charge Li-Fe ?? I do have a choice in charger menu for li-fe 3.3v / cell . I try to charge 0.2 amp in 2cell 6.6v but do get error mess: high voltage overload
hans_swe is offline
Old 12-04-2009, 04:37 PM
Trader Rating: 46 (100%+)
what charger are you using? I'm using a hyperion with mine and it's charging fine.
Apex is offline
Old 12-04-2009, 07:30 PM
cheROK1212's Avatar
i use the Hyperion duo on LiFe/ A123 mode
cheROK1212 is offline
Old 12-04-2009, 09:35 PM
make sure you set your charger to charge at 2s mode (6.6 = 2 cells in series).
hardmankam is offline
Old 12-05-2009, 01:17 AM
Default charger
i use this charger: GT POWER GTP-A6-10
hans_swe is offline
Old 12-05-2009, 07:38 AM
It could be your charger. Do you have another charger or a friends charger you could try?
Apex is offline
Old 12-05-2009, 09:13 AM
Where can one find these LiFe receiver packs for 1/12th. I suppose it works well without any regulator?
jarkko is offline
Old 12-05-2009, 12:23 PM
Team Epic sells them. No regulator is needed since it's 6.6v.
Apex is offline
Old 12-05-2009, 01:49 PM
Default li-fe
i think i found the problem !! the li-fe cells did have 7.6v so when i start charging the volt is to high. I did discharge for a while to get less volt then it did work !!! i did buy mine at rc-mushroom.com, search for 6.6v, $15 each
hans_swe is offline
