Fastest Ceramic Bearing sets.... >
Old 12-04-2009, 01:42 AM
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Default Fastest Ceramic Bearing sets....
i have run the aceer gray seal ceramics in 1/8 onroad for years with great sucess, but electric is ALOT different...i saw the orange internal seal bearings offered from boca, are these the fastest/lightest set for my 12r5.1 pancar....or anyone have another idea, maybe 40bux less that utulize the same teqnollogy,please advise,,thanx tommy
TommyBlazin is offline
Old 12-04-2009, 02:05 AM
tom_chang79's Avatar
Well, my own solution isn't a ceramic solution, but it is HELLUVA lot cheaper solution.
Go to:
http://www.avidrc.com/
All bearings on there are $1 a piece. Just replace it as you go...
David Joor, the owner is a great guy. I've ordered from him once or twice already, and have always been hassle-free and no b.s. service...
tom_chang79 is offline
Old 12-04-2009, 06:42 AM
phildoggg's Avatar
Trader Rating: 24 (100%+)
Are the Avid bearing smoother than stock? Would you be able to pick up speed going with the Avids?
phil
phildoggg is offline
Old 12-04-2009, 06:45 AM
oeoeo327's Avatar
Trader Rating: 75 (100%+)
Go to:
+1 - these bearings are really all you'd need. I'm quite happy with mine.
oeoeo327 is offline
Old 12-04-2009, 07:30 AM
John Tag's Avatar
Trader Rating: 42 (100%+)
Go to:
Exactally where most of us get all our bearings. Best $1 per ever spent!!!
John Tag is offline
Old 12-04-2009, 07:55 AM
aaron joy's Avatar
Trader Rating: 17 (95%+)
If you are looking for a smooth fast bearing I would definitely try Boca Bearings ceramic bearings. Your running onroad (little or no dust,dirt), go with a metal shield, alot less drag then a rubber shield.
I would recommend these for the 12r5.1:
http://www.bocabearings.com/main1.as...&n=*05-140C-YU
Here are Boca's dollar kit also:
http://www.bocabearings.com/main1.as...8371&n=*05-140
They have free shipping available too!!!
aaron joy is offline
Old 12-04-2009, 04:35 PM
pinggoy's Avatar
Trader Rating: 24 (96%+)
phil
avid bearing are very cheap... you just need to "break in" the bearing to be smooth ...mybe couple of runs
pinggoy is offline
Old 12-04-2009, 05:47 PM
thanks, yea i wasnt looking for a dollar bearing, rather performance....boca's are the way it seems.
Old 12-04-2009, 10:43 PM
PaPeRo's Avatar
BOCA Ceramic Ultra Seals, they're lubed for life.
PaPeRo is offline
Old 12-05-2009, 04:21 AM
Kwikvdub's Avatar
Trader Rating: 98 (100%+)
These are awesome and the only one I use: http://www.speedzoneusa.com/estore/i...index&cPath=69
Kwikvdub is offline
Old 12-05-2009, 04:28 AM
RC MARKET's Avatar
or this !
http://rcmarket.com.hk/index.php?cPath=84_95
RC MARKET is offline
Old 12-05-2009, 07:18 AM
these are excellent quality and good value, I wouldn't use anything else
http://rc4less.com/Bearings_&_Diff_B...duct_info.html
Jason
jasonb is offline
Old 12-05-2009, 09:24 AM
Originally Posted by RC MARKET View Post
WOW you got galls, after the way you just SCREWED me, i wouldnt get anything from you, even if it was free!
Old 12-05-2009, 10:48 AM
Korey Harbke's Avatar
Honestly, I don't see a need for ceramic bearings in electric on road racing. Every big race I've been too, I've just used $1 bearings from avid or someone similar. As soon as you tap a wall or two, you usually damage the wheel/hub bearings right away. I used to use ceramic... and it just got too expensive. I haven't seen any performance increase on the track with ceramic bearings, and normal bearings haven't slowed me down one bit. Just save your money and buy a good supply of the normal bearings and I think you'll be much happier.
-Korey
Korey Harbke is offline
Old 12-05-2009, 11:05 AM
Kent Beal's Avatar
Trader Rating: 70 (100%+)
What about full ceramic? has anyone had the money to try these?
http://www.bocabearings.com/main1.aspx?p=docs&id=17
Kent Beal is offline
