KO Helios and personal transponder problem? >
Old 03-02-2004, 05:37 AM
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default KO Helios and personal transponder problem?
I have recently purchased a KO helios and I have been having problems missing laps in my sedan. I relocated the transponder and reciever and even tried two different transponders and it still will on occasion miss laps.
I had a airtronics m8 before and I never had this problem.
Has anyone experienced similar problem and does any one have any suggestions.
I have also emailed KO on this issue.
Jamie
J.Gonzalez is offline
Old 03-02-2004, 07:01 AM
Matt Howard's Avatar
hmm, I've been using the helios since it came out in the states and haven't had a problem with my personal transponder.
Matt Howard is offline
Old 03-02-2004, 07:32 AM
Tommy Bergfeldt's Avatar
Actually i had some problems at a race with the transponder missing laps totally. I moved the transponder to the front of the car and the problem where gone (i had the transp on the servo before that)
When i got home i checked up the tranponder for any loose cables or things. I then noticed that the minusconector in the reciever where loose. by soldering it the transponder now has been working flawless even on the servo!
Tommy Bergfeldt is offline
Old 03-02-2004, 07:33 AM
Regional Moderator
Im with MATT on that I have been using mine from day one and no problems
Ko Racer is offline
Old 03-02-2004, 08:10 AM
RCGaryK's Avatar
The only problems with mine have been when I plug the transponder in backwards when transfering it from car to car. It glitches like crazy when that happens.
RCGaryK is offline
Old 03-03-2004, 05:34 AM
J.Gonzalez's Avatar
Default Personal transponder ?
I will check the wires in the connector and I will try relocating it to the front of the car.
Is any on using helios on 27mhz or 75mhz.
Jamie
Old 03-03-2004, 07:01 AM
I'm on 27mhz
Old 03-03-2004, 07:05 AM
I'm on 75 and haven't had any problems. I've seen problems if the tansponder is next to the receiver or if the receiver is on it's side.
Unregistered is offline
Old 03-03-2004, 07:43 AM
RCGaryK's Avatar
I'm on 27, and in 3 of my cars my transponder is mounted on top of my servo, right next to my receiver without any glitching problem....
RCGaryK is offline
Old 03-03-2004, 12:24 PM
I'm currently in 27, bought a 27 module instead of the std 40 necause it's a pain when everyone else is on the sam freq in 40.. I'm nearly all alone with my 27.125!
The transponder works fine for the moment
Old 03-03-2004, 01:38 PM
J.Gonzalez's Avatar
Default thanks
I had the recv on its side...I will try mounting it flat and relocating the transponder.
I update you on thur when I go to track.
Thanks,
Jamie
Old 03-03-2004, 01:58 PM
MarkA's Avatar
Trader Rating: 21 (100%+)
Did you also switch to a KO servo at the same time?
MarkA is offline
Old 03-03-2004, 10:13 PM
raffaelli's Avatar
is the transponder next to the receiver? i have heard of problems with the KO receives being right next to a transponder and missing laps and some glitching.
raffaelli is offline
Old 03-05-2004, 06:39 AM
J.Gonzalez's Avatar
Default thanks.
The transponder is next to the recv it is on a losi xxxs so not a lot of mounting choices...I will try moving the transponder away from recv.
