New 4WD M car - Fujin 211GO
Finally, the rumoured 4WD car made by 3racing is shown up, the design of the chassis is absolutely very look alike as TRF416.
I could tell this should be the challenger of the Atomic VM2 in 2010. Please take a look here Unfortunately, the 4WD M car race in my place is defuncted with lack of entrants, instead i will purchase 1, honest. Best regards |
Wow that looks exactly like TRF416....hmmm I m very tempted to get one..
Form 3 Racing !
if it's less than 200 smackaroo, it's the car for me. Low budget,good car, lot'Lotsa fun, PRICELESS.
24800 = $286.89
Onsale now !
http://rcmarket.com.hk/ |
How about parts? Are the 416 parts usable on this car? If yes, this is a car i will consider cos I have loads of 416 parts.
OM |
Just ordered one. Should be here in a couple of days. Not sure if I am going to regret it.
OM |
The post man showed up at my door today with the kit. Wooohoooooo!!!!!
The parts surely look like a 416. Too bad I sold my 416 some months ago and cannot make real comparison. However I still have some 416 parts that I can compare it with. So far many parts are the same with the 416. 1) Rear Diff - Same 2) Front Spool out drives - Same 3) Suspension hinge pins - Same (46mm) 4) Wheel and diff/spool bearings - Same size 5) Suspension blocks - Same, with the exception of the front rear block that incorporates the steering rack 6) Hinge pin ball - Same 7) Servo mounting bracket - Same 8) Front Drive shaft and VCD - Same with M-03 (30mm shafts) 9) Rear drive shaft CVD - Same with M-03 except with 28mm shafts. Probably can use 30mm shafts. 10) Pulleys - Same, 18T and 37T The bulk heads do look like they are from WE, I am quite convinced. Apart from the parts above, the lower deck(chassis) is a shrunk down version of a 416. Even the motor cooling ramp of 416 is 100% fit on this chassis. 416 Rear hub can be used but need to bore out the pivot pin to 3mm. The original front hub looks indestructible, but time will tell. The shock shafts are incredibly short, forgot to measure them. But shortest I've seen. However, if you have built the 3Racing F1-09 before, you will swear that the Fujin 211Go is manufactured by 3Racing. OM |
Just tested the car yesterday at our local asphalt medium traction technical track. Stock setup with Much More Sweep mini 33deg with SP11.5t brushless. The car felt very balanced, very predictable, very easy to drive, you can push it hard and it will take it. Lots of steering and rear is planted and it will go where ever the steering points.
The way the car handled really surprised me. A buddy of mine has tested many other Mini 4wd and he commented that this is by far one of the best handling Mini 4wd he has driven. Can't wait to go back to the track today!!! |
I was thinking of getting a ABC Genetic or Active M chassis for my next car but this one seems to be the better buy. The Atomic VMII is too expensive imo.
you guys should search "416 made in china" on this site.
I had two of these-- not HORRIBLE cars.. but there are some tolerance issued which make the chassis impossible to keep flat. good value for a beginner.. |
Originally Posted by dameetz
(Post 6797563)
Will you carry full parts for this car?
Originally Posted by Keith Billanti
(Post 6798903)
