TT01 Drift / Rear Diff problem. Front and Rear Wheels go in opposite directions! >
Old 11-30-2009, 09:20 AM
Default TT01 Drift / Rear Diff problem. Front and Rear Wheels go in opposite directions!
Hello!
Once again thanks for such a wealth of great info, has helped loads..
I now have a TC5R to help my transition from a TT01 and cannot wait for the days to get lighter so I can practice on my local track...
Can you please tell me what I have done wrong with the TT01? I wanted to make it drift better so locked up the rear diff using blu-tak, and now the back wheels spin backwards and the front wheels still go forwards - so the car goes nowhere!
I checked the settings on the transmitter and they are both set to normal, not reverse, so it isnt that. Just really confused as to what is going on!?
Thanks again for any time you can spare...
Kevin
tapeykev is offline
Old 11-30-2009, 09:23 AM
RobS's Avatar
Chances are, you put the rear diff in backwards when you rebuilt the car...
RobS is offline
Old 11-30-2009, 09:25 AM
Ah! that would make perfect sense... sorry for being such a useless newb
Can't wait to finish work I can go and un-do my great (erm, stupid) mistake!
tapeykev is offline
Old 12-01-2009, 04:51 AM
Hello,
I tried fitting the rear diff round the other way and still no joy - I had put it back correctly. Also tried putting it round the wrong way to see what happens, still nothing.
I then unlocked it by removing all blu-tack and this made the car work normally so it must be something wrong with the way I am locking the diff. I just put blu-tac in all of it - to stop it moving at all.
Is this wrong?
Thanks again..
tapeykev is offline
Old 12-01-2009, 05:22 AM
Redwood's Avatar
I don't have a TT-01, but about 10 years ago I had a TL-01, which had gear diffs, which is the only reason I can think could be the issue, I had a look because I was intrigued as to how to lock a 'planetary diff' and found this:
http://www.rcspares.com/drift-rc/loc...ferential.html
Seems to be what you need.
Regards
Neal
Redwood is offline
Old 12-01-2009, 09:19 AM
Thank you,
I found this link too ...but the method I used would also lock the diff but I can't see how this would make my front and rear wheels turn opposite directions.. there must be something simple I am overlooking... I have emailed the people at rc experts, will post my results when its working!
tapeykev is offline
Old 12-01-2009, 10:12 AM
i filled my rear diff with silicone sealent and it didnt turn backwards !!!
dont know what is wrong with it
sidecarphil1 is offline
Old 12-02-2009, 04:45 AM
I have been a bit stupid with this one, OK so I didnt put the diff in backwards, but I also didn't take the alloy prop shaft out so the car is still trying to run as 4wd instead of RWD... not what you want with a drifter!
I will take this out tonight and flip the reverse switch on the transmitter and she will be ready to run...
One thing I have noticed is that where I have taken it apart so many times, the screws have eaten into the plastic and de-threaded themselves. Going to have to put sealant down there to make the screws go tighter...
So glad I have the TC5R now as I can't be dealing with this limitation on plastic kits anymore, and I have hardly used the thing!
tapeykev is offline
Old 12-02-2009, 04:58 AM
Timbulb's Avatar
Who told you you can't drift with AWD? Ever seen this?
http://www.youtube.com/watch?v=HQ7R_buZPSo
Timbulb is offline
Old 12-02-2009, 06:13 AM
No one told me that I just thought it makes sense... would drifting be better with RWD or AWD/4WD with R/C cars? I know that with the real drifting cars they sometimes make them RWD and as I cannot get my front and rear wheels to go the same way... this seemed like the only fix....
Would love to hear different though!
(Thanks for the link, will check it out after work)
tapeykev is offline
Old 12-02-2009, 08:08 AM
Timbulb's Avatar
I think most RC drift cars are actually AWD.
Timbulb is offline
Old 12-02-2009, 08:24 AM
Doh! in that case, it looks very much like I am going to be one of the few RWD drifters
Unless anyone can clear this up for me... I just want to play now, not sit there scratching my head!
tapeykev is offline
Old 12-02-2009, 08:30 AM
rockstar81's Avatar
One of the diffs has to be in backwards, no ifs, ands, or buts about. That is the only possible way for a shaft drive car to do that. What happens if you turn the diff around?
rockstar81 is offline
Old 12-02-2009, 08:54 AM
Thanks, I tried that but still didn't work...
The car works fine without the diff locked, but as soon as its locked, the problem comes back..
I checked after the first suggestion of diff being wrong way round, and it was in the way the manual shows. So I changed it to the other way, and back again, and still no luck, the only thing that makes it work is when it is not locked... so I cant help but think it is something to do with the way I am locking it... but this can't be true either!
Confused
Maybe the front diff is in wrong....?
tapeykev is offline
Old 12-02-2009, 02:08 PM
rockstar81's Avatar
How exactly are you locking it? There is no feasible explanition for this, locking it won't reverse the whole diffs rotation.
