Whats everybody's WGT setup? >
Old 11-22-2009, 06:58 PM
trackdesigner71's Avatar
Default Whats everybody's WGT setup?
Thought Id get a thread started to see what everybody is running in their WGT. Im not 100% set with mine as I need an ESC and a body but maybe I can glean some helpful info in the meanwhile through this as well. I have a CRC Pantoura and a LRP Vector X11 13.5 brushless motor. I was originally going to set it up for 4C before the change to 1S LiPo at the IIC in 2009 and Snowbirds in 2010.
trackdesigner71 is offline
Old 11-22-2009, 07:10 PM
Uga
Uga's Avatar
Chassis: BMI DB10R
Speedo: SP GT LPF 1.1 for now, Tekin RS Pro on the way
Motor: Novak Ballistic 17.5T which I think I might have overheated with a terribly wrong gearing in it's first runs (~120C), so I have ordered a fresh Tekin Redline together with the speedo.
Battery: Intellect 2S 4200mAh 30C saddle
Servo: Futaba S9650
Radio: Sanwa M11
Uga is offline
Old 11-22-2009, 08:08 PM
Trader Rating: 8 (90%+)
Associated 10R5
Speed Passion GT V 2.0
Sp 13.5 or Novak 13.5 Geared with 88sp 40-47tp
SMC 4000 25c
Ko Ex-1 sprectrum mod
Crc or Jaco spec tires at 55-57mm tire front and rear.
I am using a fairly high rollout.... #[email protected]& Boost. I keep up just fine just have tp gear higher and my mtors are around 110 to 140 never really higher......
Tha Skinny is offline
Old 11-23-2009, 05:15 AM
2wdrive's Avatar
@trackdesigner. When are you going to race? I read for almost 2 years now that your planning to race the pantoura. You can buy a second hand esc for not so much and go driving/racing, even with old sub c cells. A body isn't that much either.
@ Uga
Be sure to monitor the temps of the tekin redline closely. You don't want to get it above 70 degrees celcius otherwise the motor fades noticeble while driving. It doesn't have cooling holes so the temps inside the can are even higher. I basicly destroyed a brand new 10.5t in one day when it got 91 degrees celcius. Speed was great in the beginning though , 85-88km/h (55m/h) on a track with roughly 100 meter straight (330 ft). I never got that same speed again after that.
anyway....
My new car for the indoor season 2009-2010
Chassis: BMI DB10R
Speedo: Tekin RS Pro
Motor: 13.5t epic duo2
Battery: 2 year old Yuntong 2s 4800 20c softcase saddlepacks. Intellect 2S 4200mAh 30C saddlepacks on the way
2wdrive is offline
Old 11-23-2009, 10:39 AM
@ Uga
anyway....
Chassis: BMI DB10R
I know 2wdrive...it bothers me more and more as the days and months go by. Money has always been the biggest obstacle and once that isnt an issue its finding time to go back home (they are running a WGT class at a track about 20 minutes from my house in Portsmouth but I live in Lynchburg now. the nearest track I can think of other than that is up near Northern VA and MD).
Old 11-23-2009, 02:05 PM
LOW ET's Avatar
Trader Rating: 103 (100%+)
Chassis: rc10r5
Speedo: lrp spx comp
Motor: lrp x11 13.5t
Battery: thunderpower 5000-1spr
Servo: jr z3650
Radio: dx3r
Tires: jaco wgt
Body: sophia gt
LOW ET is offline
Old 11-23-2009, 03:53 PM
tallyrc's Avatar
GENX
GTB
Novak 13.5
SMC 4900
JACO pink/purple (probably switching to pink/dbl pink)
Novak Smart Boost
Proline Sophia
Luck
Other Peoples Paint and Wheel Marks
Secret Sauce
Loose Nut Behind the Wheel
tallyrc is offline
Old 03-29-2015, 12:47 PM
greasy geek's Avatar
Crc gen 10 le with se slider.
hobby wing 1s
team powers motor
sanwa radio
black art body
greasy geek is offline
Old 05-14-2015, 05:11 AM
Trader Rating: 21 (100%+)
Are there any setup sheets suspension wise? like i found them for the TC, but cant find much for the WGT..hell cant find much for 1/12th pan either for that matter
phatboislim is offline
Old 05-14-2015, 08:40 AM
wwddww34's Avatar
Trader Rating: 9 (91%+)
There are plenty of setup sheets (for all types of cars) that you can pick from on this page --> www.petitrc.com/_forumphp/sheet.php
wwddww34 is offline
Old 05-14-2015, 10:28 AM
oh wow, i remember that petitrc.com but every time i google it it's for tc6 setups. thanks a ton
edit:
ok i've checked out a few and they are about 5 years old...any more updated setup sheets?
Old 05-14-2015, 11:42 AM
dawgmeat's Avatar
Chassis: BMI DB10R
Speedo: Airtronics Vortex Zero
Motor: SkyRC Ares 17.5
Battery: AGA Power 5800 70C
Servo: Futaba S9670SV
Radio: Airtronics MT-4S
dawgmeat is offline
Old 05-14-2015, 02:25 PM
Lil Paul's Avatar
Default WGT Servo
I am going to run WGT for the first time, I am building the car with the Futaba 9650 servo, thats what I ran in my 1/12th scale. Will that work for my WGT or do I have to use a full size servo?
Lil Paul is offline
Old 05-14-2015, 02:28 PM
wingracer's Avatar
Trader Rating: 24 (100%+)
Perfect WGT servo.
wingracer is offline
Old 05-14-2015, 02:29 PM
Lil Paul's Avatar
I agree also, that much of the info out there is out-dated. I know the cars havent changed much, but figured guys may have learned some new strategies having been able to put alot of track time under a platform that hasnt changed.
Lil Paul is offline
