-   -   cigarette lighter output?? (https://www.rctech.net/forum/electric-road/346010-cigarette-lighter-output.html)
wantboost 11-22-2009 11:42 AM
The the average cigarette lighter out?
Scottmisfits 11-22-2009 11:49 AM
3amps or less. Not enough to charge a touring car battery.
wantboost 11-22-2009 01:25 PM
i charge my lipo at 2amps on my car battery in 70min. so using cig lighter would be fine...
i guess u mean a really fast charge?
ZiG-87 11-22-2009 01:28 PM
Depends on the car, I can get 15 out of mine if I had something that actually used that much current.
kschu 11-22-2009 04:54 PM
why dont direct connect the charger to the car battery terminal ??
i used to charge my NIMH cell 6amp last time without any problem.........;);)
Manning 11-22-2009 05:36 PM
True cigarette lighter outlets are usually fused at 8 amps, so regular charging should work just fine. I've charged many batteries using a cig lighter outlet while driving to races.
"power outlets" are generally fused at 15 amps or so. The limiting factor is how good the contacts are.
