what makes ur com shape into a cone shape >
Old 02-27-2004, 10:28 PM
tc3 racer sc's Avatar
Default what makes ur com shape into a cone shape
just a little question what make ur com shape into a cone at the end whn u cut it what im doing wrong do i need a new lathe bit plse help
tc3 racer sc is offline
Old 02-27-2004, 10:37 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Make sure your lathe is aligned correctly and the bit cuts straight with the comm.
Randy Caster is offline
Old 02-28-2004, 10:44 AM
popsracer's Avatar
tc3 racer sc;
Make sure your Bit is sharp and has been set-up properly from the centerline of the lathe.
Either one will cause poor cuts if wrong.
Also if the drive O-ring is worn out, it will not hold the arm down tight against the blocks. This coupled with a worn Bit will cause the armature to be pushed off the blocks when cutting and a tapered (and bad) cut will be the result.
popsracer is offline
Old 02-28-2004, 11:39 AM
Tech Legend
Wild Cherry's Avatar
Check your`s lathes bridge ways & see if they are in alinement (staight) ( two screws with lock nuts )
If one is tighter or looser , the lathe will cut a cone shaped com.
Wild Cherry is offline
Old 02-28-2004, 12:20 PM
kewdawg's Avatar
Make sure the armature is shimmed correctly when you put it on lathe, also.
kewdawg is offline
Old 02-29-2004, 07:33 PM
Default thxs for the help on the lathe problem
thxs for the help guys i will look at it agin i think i need a new bit it been 4yrs on the lathe i get some one to help me out thxs
