mamba 5700kv gearing >
Old 11-19-2009, 10:35 AM
Default mamba 5700kv gearing
i have a schumacher mi3.5 and i got the mamba max pro esc with the 5700kv motor. i just got this motor. i damaged my other one from setting my gearing to high. i previously had a 66t spur gear with a 41t pinion with 32 lipo 20c 5000. that destroyed my motor lol. before i had that set up i was running the same battery with the stock eighty-nine tooth spur gear and a twenty took pinion.
im a speed freak.. so im trying to get as much as i can without having to buy another motor. i set the car up with the stock spur gear but put a 30t pinion on it this time. i havent ran it yet but is this gearing safe??
i checked that rc gearing site but they didnt have any schumacher set ups with the mamba. im shooting for 60 65 mph. how can i gear to reach that safely?
im working with forty-eight pinch spurs and pinions also
bernyberns is offline
Old 11-19-2009, 01:22 PM
any help??
Old 11-19-2009, 01:32 PM
lowcel's Avatar
Trader Rating: 80 (100%+)
Do you have a temp gun? If so I would experiment and find out how far you can push it while still keeping it under 170.
lowcel is offline
Old 11-19-2009, 02:03 PM
no sir i don't.i will have to get one
Old 11-19-2009, 02:44 PM
I don't think you should be running more than a 22/89 or your going to melt down again. The 5700 should be run with low timing or the stock timing. It's a high rpm motor. Trying to over gear it is bad. I assume your trying to do top speed runs on the street. On a carpet track I run around 9:1 FDR (89/18) but that's a road course. I only run 2 cell roar legal lipos.
Eddie_E is offline
Old 11-19-2009, 03:00 PM
phildoggg's Avatar
Trader Rating: 24 (100%+)
Well it depends on if you are doing speed runs(2-3 passes then a break) or just wanting to run in a parking lot at high speeds. I have a tc4 setup with the 5700 geared 30/60 and on 3s lipo I have hit 80mph. with this gearing it will get hot after a couple runs. 30/89 gearing should be ok but def. keep an eye on temps.. heres a link to a good speed calculator.
http://scriptasylum.com/rc_speed/_top_speed.html
hope this helps.
phil
you need to know the diff ratio for the car and the trans should be 1 in the box. Its a great tool and pretty accurate,till wind resistance starts.
phil
phildoggg is offline
Old 11-19-2009, 06:04 PM
thanks for all the info. and phil if u was hitting eighty with 30/60 then my car must have been able to go eighty-five or 90 with my 41/66. the car was so damn fast parts would come apart man. no lie lol. the car sounded like a vaccume cleaner when i picked it up and gased it. was epic.
but i paid the price for it lol.
anyway i ran the 30 eighty-nine tonight. its nice and fast. i checked the temps every couple of minutes. i get about 10 maybe 15 minutes before i have to stop and let the motor cool down.
how in the heck do these guys on youtube get their cars so fast without buring out their motor?
Old 11-20-2009, 03:34 AM
diozxlive's Avatar
wats the max temp for the m5700?
diozxlive is offline
Old 11-20-2009, 07:01 AM
phildoggg's Avatar
I think its between 180-200 for any brushless motor. I myself don't like it anywhere near 180.
hey bernie I bet geared like you were it was really fast.. just keep an eye on temps and have fun.
phil
