Need Help! Car Glitching!! >
Old 02-26-2004, 08:48 PM
  #16
MugenMTX3Kid's Avatar
Ok, i went outside just now with my receiver on top of my upperdeck. Still glitches!!
MugenMTX3Kid is offline
Old 02-26-2004, 08:59 PM
  #17
Techart27's Avatar
Default Hope what my solution helps!
Techart27 is offline
Old 02-26-2004, 09:03 PM
  #18
It may be my reciever... I did what Techart27 suggested and it still glitches... I took my receiver away from the esc and the car and put the the car on a box so the wheels can roll. So i went outside and around 20 feet it, it starts to throttle and steer. 2 sec at a time or so.....
Ill go try my MX3 on it
Old 02-26-2004, 09:07 PM
  #19
SlobbaTech's Avatar
Make sure the circuit board that sticks out of the speedo isn't touching the side of the chassis. Take your battery put and set it on top of the car somehow and drive the car and see if it still glitches, if doesn't then need to put some tape on the chassis so the battery bars can't touch the chassis. Can try twisting the wires to the motor then resolder them on. You definately need to clean up the wires to the receiver, you shouldn't tie the speedo and servo wires together. Make sure the little metal things on all ofthe Rx type plugs on Rx and speedo are pushed in fully. Can also try running servo wire over top of the battery. Wouldn't hurt to move the antenna mount somewhere less busy.
SlobbaTech is offline
Old 02-26-2004, 09:13 PM
  #20
fatdoggy's Avatar
Have you tried different tx/rx crystals, as I suggested? It could be as simple as a bad crystal.
fatdoggy is offline
Old 02-26-2004, 09:26 PM
  #21
My circuit board is kinda close and maybe touching.. ill check that out..
Fatdoggy:
Dont have another rx crystal... ill just try my MX 3
Old 02-26-2004, 09:35 PM
  #22
DOMOisCOOL's Avatar
I have mine set up like this:
Try it, see if it works. If not, we'll contact through AIM
DOMOisCOOL is offline
Old 02-26-2004, 09:36 PM
  #23
DOMOisCOOL's Avatar
On this old pic, check out where I put the antenna.
Old 02-26-2004, 09:40 PM
  #24
Techart27's Avatar
Hey DOMOisCOOL, hows the Monster Stock motor ur running? U recomend it?
Old 02-26-2004, 09:41 PM
  #25
he drifts with it and race, try it if you want..
Old 02-26-2004, 09:43 PM
  #26
Techart27's Avatar
Heh, how'd u no?
Old 02-26-2004, 09:44 PM
  #27
Techart27's Avatar
U no u can be talking with me through aim instead? lol
Old 02-26-2004, 09:45 PM
  #28
Techart27's Avatar
Yo, u wanna drive 2morrow? I feel too sore to go to practice again
Old 02-26-2004, 09:46 PM
  #29
DOMOisCOOL's Avatar
Its really fast if you maintain it good and have right gearing. Im running 25/87 on it. Pretty fast acceleration.
Old 02-27-2004, 11:51 AM
  #30
Also make sure you have good connections between your batteries in your radio, yep... if the little springs that your AA's sit on in your battery cradle are worn out that will cause you to glitch.
ZER01 is offline
