Old 03-04-2002, 12:08 PM   #31
Post Better Adhesion
Before you apply double-sided tape to anything, remove all residue then wipe it with alcohol. For a longer, better adhesion.
rctc3 is offline   Reply With Quote
Old 03-04-2002, 12:11 PM   #32
Post Shock Cap Coupler
Stripped or weak threads in your shock cap may cause the damper to seperate unexpectedly. You can temporarily repair this using an automotive hose clamp around the area where the cap meets the shock body.
Old 03-04-2002, 07:04 PM   #33
Kenneth Tan's Avatar
Post
Get hold of the Ride Shock Builder. It comes as a container with a pump. The pump is supposed to de-pressurize the container and force the air bubbles in the shock to rise more quickly. Upon releasing the pressure, substantial amount of air bubbles would have burst. Repeat, until free of bubbles.
In an experiment, I used the normal way of moving the shock piston up and down slowly to get rid of the air bubbles. I thought I had got rid of all the air. When I used the builder afterwards, I was surprised to see much more air bubbles surfacing. Suspect that all those air bubbles might have been hiding under the piston or between the O-rings. Definitely, one of the better R/C car tools out there.....
Kenneth Tan is offline   Reply With Quote
Old 03-04-2002, 07:20 PM   #34
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Default Re: How not to crash into things
Originally posted by Jack Smash
When you are about to hit something, use your transmitter to tell the car to avoid it. Sometimes your car maybe going to fast and it will outrun the signal from the transmitter. This will cause your car to crash into it anyway. If you find your car outrunning your transmitters signal, slow down a little and allow the signal to "catch back up"
LOL
Speedo is offline   Reply With Quote
Old 03-05-2002, 09:25 AM   #35
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Default Associated Shock Pistons
If you install your shock pistons with the numbered side up, you wont have to take the whole shock apart to remember which piston you have.
Jack Smash is offline   Reply With Quote
Old 03-08-2002, 05:59 PM   #36
Post beginners
usually if your a beginner or new to r/c go with a rtr (ready to run) kit it gives u everything u need.
Old 03-10-2002, 10:54 AM   #37
Post broken a-arms
if u break your front or rear a-arms on your tc3 they can be switched so the rear a-arms fit the front and the front fit the back cause they're pretty much the same just a little taller.
X-ray T2, Tips and Tricks trailranger Electric On-Road 4 05-17-2008 02:44 PM
M11 TIPS AND TRICKS!!!!!! S-T-R-l-K-E-R Electric On-Road 11 08-11-2005 11:32 PM
tips and tricks XXX-NT streetstock Electric Off-Road 2 05-13-2005 10:50 AM
JRX-S Set up tips, tricks, and set ups bigdog xxx-s Electric On-Road 5 04-20-2005 10:12 PM
Tips & Tricks Steevo Electric On-Road 54 08-08-2003 10:09 PM
