RS Pro and Ballistic 13.5 - FDR ? >
Old 11-17-2009, 11:45 AM
amnesia's Avatar
Default RS Pro and Ballistic 13.5 - FDR ?
Hi all,
Can someone recommend a good starting FDR for a Ballistic 13.5 with the RS Pro. Our track is small (a bit bigger than a basketball court) indoor carpet with rubber tyres.
This is a typical layout in the school hall.
I was running a speed passion v2 at 6.0FDR.
Does starting at 6.5 ish and working my way down sound about right?
Any recommendations for RS pro settings for the ballistic ?
Cheers,
Daniel.
amnesia is offline
Old 11-17-2009, 12:02 PM
Yes play around the 6,5FDR. maybe even lighter.
What is your Boost settings and your Turbo and turbo delay?
mikky32 is offline
Old 11-17-2009, 12:39 PM
amnesia's Avatar
Turbo delay = 0.6s
Turbo boost = 20 (max ?)
Boost (timing) = 6 for the Speed Passion.
Not sure what the default timing is on the Ballistic. I am not going to play with the timing on the new motor for now.
Will probably start off with 0 advance on the Tekin and get the infield gearing sorted before I 'play'.
amnesia is offline
Old 11-17-2009, 01:01 PM
Most of the motors have a standard 12 degrees timing.
Best is to set the motor on 0 and the Boost around the 25.
If you keep the motor on the standart timing set the Boost to 10 to 15 and play with the gears. Turbo delay around 0,7.
mikky32 is offline
Old 11-17-2009, 01:06 PM
amnesia's Avatar
Cheers !
I will give it a go and see how I get on.
Daniel.
amnesia is offline
