_-_-taking Care Of Your Brushless Thread+++
OK I WANT TO START THIS THREAD as i'm wondering how i should take car of my hacker brushless 6T unit? maybe we can help each other.
my hacker was not spinning smoothly when i turned it with my finger. like it had sand in it!?
in a fit of boredom i opened up the hacker, (whilst doing this i was screaming "AAAAAHHHH" in my mind thinking i'm gonna stuff it)
anyway after finding that i didn't break anything, (phew!) i saw a sh$T load of dirt and small pebble rock particles in it!
QUESTION;
how should i take care of my hacker?
i took out the magnet "thing" and put the case in a ultrasonic cleaner with shellite. i oiled the bearings and stuff but should i have done this? i didn't stuff it up did i?
my main hobby is nitro that's why i ask.
QUESTION;
Trader Rating: 22 (100%+)
when you say "case" do you mean the part with the windings in it? i would give it a blast with some motorspray.
mount the speed controller away from the sides of the chassis, if it gets hit it may stop working like mine did, ive been waiting several months for hacker to fix it.
Your Hacker motor is pretty much bullet proof.....just blow it out every now and then.
Dirt will get in due to the opening where the wires come out.
You can clean your bearings as you would a brushed motor.
Putting tape over the end bearing helps prevent dirt getting to your bearing.
Sit back and enjoy watching the brushed motor ppl cut their comms all afternoon...
yeah i sealed up all the holes. but i forgot about the wire openings. might try using .....something for that. maybe gasket sealent. the type used in my nitro engines. i can be peeled of
The windings on the inside are coated (electrically insulated) with a varnish. If it's scrubbed off, or removed chemically (ultrasonic and motor spray) you can short the windings and be in big trouble. Simply blow it out w/air, or best to keep the crunchy stuff out of it w/silicone sealant, or as you said - gasket sealant.
Shawn Palmer
Shawn Palmer
Originally posted by AWOLsoldier
What's the typical size race for brushless where you guys go? My track doesn't do brushless.
Shawn Palmer
Shawn Palmer
brad have you ever maintained your hacker? i'm interested as to what you did?
shawn are you sure it has varnish on the windings? i didn't see anything?
How fast?
How fast is ur hacker 6t, maybe compare to novak ss?
Re: How fast?
hehehe very quick!.....down a straight. i still can't keep up with the pro's though the top drivers in oz are probably just as quick with a hacker as compared to a really good brushed.
down the straight of a major track in nsw it was/is as quick as a old novarossi s1 3 port i had....maybe a few clicks under.
i just brushed out he end cap and oiled the bearings. The motor cleaner will not hurt any of the windings (otherwise it wouldnt be called electric motor cleaner), so spray away.
Good point cold - motorspray should be OK.
Yes, the varnish is very thin, clear, and tough, but it's there. Otherwise the motor would be one big electrical short and not work. (technically it's 3 equal electrical shorts)
Shawn Palmer
Shawn Palmer
Shawn Palmer
Shawn Palmer
